I live in a condo/apartment building. The water heater is an Eemax280T2T. I only am getting Luke warm water for a couple of minutes. The eemax unit and the circuit breaker box are both in my apartment. Is there any troubleshooting steps I can take to fix this myself?
SOURCE: Reliance 40 gal hot water heater. Model 54020RS960
Hello Bill The temp stat is a square box clipped in under the elements .Can be replaced in 5 minutes.Need a large flat screwdriver.
SOURCE: CARVER CASCADE 2
Hello .. when an electric water heater only gets warm, it is usually the thermostats. I would replace the thermostats, make notes where the wires are connected .. make sure after replacing that the back of the thermostat is flat against the metal of the tank.
Please Vote !!
SOURCE: no hot water, control board light stays green
It may be bad thermostat terminals of the water heater, or, alternatively, the very top heating element is in need of replacement. See this handy diagnostic article for more info:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Heating_Systems_Water_Heaters_Cold_Water_Still_Released_Despite_Water_Heater.htm
Hope this helps.
Brad
SOURCE: Hot water gets cold after a couple of minutes
hi do you have 3/4 inch cas line running to it? if you only have 1/2 inch it is too small and running out of gas and shutting down. ed
SOURCE: my jAYCO rv only get luke warm water for as few seconds and
Also check that by-pass valve(s) is/are, in proper position at back of tank.
