Kitchen Appliances - Others Logo
Question about Star Kitchen Appliances - Others
Fryer won't lite piolet lite is burning
Model 216 pilot is lit turn on tempeture knob and burners won't ignite
5 Related Answers
Anonymous
  • 254 Answers
SOURCE: Thermostat Issue DCS Fryer??
This sounds to me like the thermostat is not sensing and is reading a closed circuit all the time. You will probably need to replace the thermostat.
Thanks
Zerko
Posted on Aug 30, 2008
Anonymous
SOURCE: Pilot Light
i had this trouble with a different fryer. We had lpg instead of natural gas. check youre using the correct gas.
Posted on Oct 20, 2008
Anonymous
  • 21 Answers
SOURCE: Fryer pilot lit but main burner does not come on
IT IS A GAS PRESSURE PROBLEM CHECK TO SEE IF THERE IS A GAS REGULATOR IN LINE WITH THE GAS PIPE TO THE FRYER IF SO ADJUST REGULATOR TAKE TOP ALUMINUM SCREW OF YOU WILL SEE WHITE PLASTIC SCREW TURN WHITE SCREWW TO THE RIGHT ALL THE WAY IF SAME PROBLEM OR NO REGULATOR RESTICTION IN GAS LINE
Posted on Nov 19, 2008
Anonymous
  • 30 Answers
SOURCE: burner doesn't ignite
did you check to see if the knob on the gas valve is set to on?
Posted on Mar 31, 2009
Capt Rick
  • 81 Answers
SOURCE: IMPERIAL FRYER
Replace the thermostat
Posted on Jul 25, 2009
American range fryer will not light...the knob you turn to light the pilot light will not turn.you can push it in but won't turn.please help
From the Owners' manual:
LIGHTING
1. Before attempting to light this appliance, the door if so equipped, shall be open.
2. Turn the appliance manual gas shut-off valve to the OFF position.
3. Turn the combination gas control knob to the OFF position.
4. Turn the thermostat control to the OFF position.
5. Wait 5 minutes.
6. Turn the appliance manual gas shut-off valve to the ON position.
7. Turn the combination gas control knob to the PILOT position.
8. Light the pilot with a match while depressing and holding the combination gas control knob until the pilot remains
lit upon releasing the gas control knob.
9. Turn the combination gas control knob to the ON position.
10. Turn the thermostat control knob to the desired temperature to turn burners ON.
11. Ensure that the door is closed during operation.
12. For complete shut-down, repeat steps 2, 3, and 4.
It won't turn any further until the pilot is lit and stays lit.
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Fryer wont lite when temp knob is turned up to 350 range pilot is lit
Observe the thermostat when set to higher temp, you should hear a clicking sound as the mechanical contacts inside closes, at this point, burners should fire up.
Thermostat can be tested by checking the continuity across its terminals (using an ohm meter) when set to a temperature higher than the oil temperature.
Also, the thermopile must be free of soot or any form of dirt and the pilot must have good flame quality, gas pressure should meet the nameplate's requirement.
3answers
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
1helpful
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
1helpful
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Deep fryer burners will not lite
Does this fryer plug up to power of not?If it don't ,then thehi limit is out,need to reset it and try lightning it back.You will need to hold if for a minute.At this time if it don't stay lite,then replace the pilot thremcouplen.
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
