Question about Pioneer SX-205 Receiver
No sound from tuner - Pioneer SX-205 Receiver
Sound does not work.
either is sound IC has blown, or the sound section of the tuner needs a repair. I have repaired many tuners for sound. Some technicians never repair a tuner hence it would need a replacement if it can be physically removed. If a tuner is printed on the main board the whole board may need to be replaced.
Nov 02, 2013 | Toshiba 57H83 57" Rear Projection HDTV
No picture or sound. Is this a tuner problem? any help, please?
A no picture and no sound problem could not be a tuner problem. To test if it is a tuner problem, there must be a sound and picture using the rca input at the back of tv. I would suggest to resolder tuning section not the tuner itself. Thanks for using Fixya.
Oct 14, 2013 | Mitsubishi CS-26201 TV
Signal to the output jack shuts off when the tuner is not on. I have an DJ Ashba model Ovation.
Some tuners require three pushes to cycle through the states: 1. Tuner on with sound going through 2. Tuner on with no sound. 3. Sound goes through. Many tuners were just on and off, but these new ones with the sound and tuner state are confusing people.
Jul 20, 2011 | Ovation DJA34-CHB Limited Edition DJ Ashba...
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Frontech tv tuner card jil 0606could not initialize capture devic
CLICK HERE
or go to http://www.sendspace.com/file/jxlowm
Download the file.
Driver, Software, Instructions included.
Oct 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
Line in problem of tv tuner with DG31PR board
u must connect speaker on tv tuner card;s jack. and go in control panel click on sound and audio device than select audio and change sound playback default device.thanx enjoy good luck plz vote on my comments
Jun 16, 2009 | Intel DG31PR Motherboard
Hissing sound
Do you mean audio hissing sound or is there smoke coming out the back?
Audio hiss with the FM tuner selected would mean it's between stations or you don't have an antenna. Try tuning around the band with an antenna.
Close what?
Connect what to what tuner? It has an internal tuner.
Apr 04, 2009 | Audio Players & Recorders
Pioneer SX-205 Receiver Logo
47 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
