Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
SOURCE: need a manual for Coleman furnace
how do I hookup my Coleman Sedona refrigerator to the propane?
Posted on Jul 01, 2009
SOURCE: manual on how to clean Coleman furnace model #
Here's a web link to the Technical Manual for your furnance. This should contain all the tech specs for your unit.
http://www.winfieldsupply.com/images/HVAC/dfahtechguide.pdf
Also, please give Coleman customer service a call at 1-877-726-5362 to obtain a Owner's Manual for your particular unit, which should contain the periodic service schedule for your furnance. Here's a link to the Coleman site with maintenance tips for your furnance.
http://www.colemanac.com/homeowners/maintenance_tips.asp?prodLine=1&ProdID=0
Hope you found this info helpful and best regards!
Posted on Aug 06, 2009
SOURCE: New Furnace Coleman Model 8623A Ser#037873318
Red wire to R. There may be a R, Rc, Rh, You will have either one or 2 of these. They shaould be jumped together with a small jumper from the factory. Then white to W, green to G and yellow to Y
Posted on Mar 20, 2010
SOURCE: My Coleman direct vent forced air furnace
two things the pressure switch not working or the fan control afc not working could need cleaning at the back of the afc try this the afc works on temp rise to bring on the fan afc temp fall to shut of fan so it sound like the afc is not coming on at temp rise, also check if air filter is clean
Posted on Jan 20, 2011
Feb 17, 2018 | Coleman Heating & Cooling
Nov 22, 2017 | Heating & Cooling
Dec 22, 2015 | Coleman Heating & Cooling
Jan 02, 2015 | Heating & Cooling
Mar 11, 2011 | Coleman Heating & Cooling
Jan 19, 2011 | Coleman Propane Forced Air Heater...
Jan 15, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Nov 07, 2008 | Heating & Cooling
May 15, 2014 | Coleman Propane Forced Air Heater...
634 people viewed this question
