Question about Samsung Digimax 301 Digital Camera
How to unlock sd memory card ,the camera tells me card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Sep 20, 2014
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: memory card is locked
There is a small tab (like a very small hole with a sliding piece of plastic) on the corner of the memory card. Slide it to unlock it :)
Posted on Dec 17, 2007
otacon
Damen Wong
  • 1950 Answers
SOURCE: Can I use a memory card SD 2Gb in a camera Samsung Digimax S500 ?
Yes, you can use a 2 GB SD card in your camera.
Posted on Feb 27, 2008
Anonymous
  • 3 Answers
SOURCE: Card Locked
I had this problem too. I took out the SD card (which was unlocked), locked it, then unlocked it again. Then I put it back in the camera and it recognised it as unlocked.
Posted on Mar 23, 2008
Anonymous
SOURCE: memory card stuck in camera slot
No need for pliers! I was able to eject the memory card by sliding a packing knife along the edge of the memory card. The blade was very thin, narrow, and long. I'm not sure if a regular box cutting knife blade would do. I've been able to eject the memory card with ease about a dozen times using this method.
Since I can't eject the SD card on the go, I use the USB cable to download images from the camera. Glad to know I can remove this when absolutely necessary, but sure wish I could remove anytime I'd like.
Jason
Posted on May 11, 2008
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: Memory card locked
Hi there
Take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
Posted on Mar 05, 2009
2answers
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
1helpful
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. what i do?pls explain with pictures
If the memory card is a SD memory card then
1helpful
SD memory card is locked. How do I unlock it?
1helpful
How do i unprotect my sd memory card form my nikon cooplix touch screen camera ?
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
When i take a picture it tells me that the memory is full and i have installed a new memory card. The camera is new
I will assume that this camera is using a SD card as there is no make or model shown. All new memory cards need to be formatted to the camera so the camera can read the card. Also SD cards have a lock on the side it's a little sliding switch that can be very easily pushed to the lock side while installing the memory card here is a diagram of the lock and unlock position of this card.
Formatting a card must be done in the camera the memory card is being used in your owners manual may refer to formatting as initializing
Dec 30, 2010 • Cameras
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. How do i fix this?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
3helpful
2answers
Microsd memory card is locked
there is switch lock and unlock on the edge of memory card .
3helpful
The camera tells me the memory card is locked!
If it is an SD card then there is a small slider to lock and unlock the card on the side
Samsung Digimax 301 Digital Camera Logo
Top Samsung Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Samsung Camera Expert? Answer questions, earn points and help others
