Question about Sony KP-53S65 53" Rear Projection Television
SOURCE: Sony KP-53S65 standby light is
just look for the rating of the capacitor..it's voltage and capacitance...any electronic parts store has sit..just replace the capacitor..
Posted on Jun 21, 2009
SOURCE: sony rear projection tv showing double
If you have a CONVERGENCE problem and it will not adjust---the two STK-392-150 Chips this set uses need to both be replaced and the set adjusted with the original remote control.
You can, if you are able to do the repair, buy a pair of chips for less than 14 dollars plus shipping on Ebay.
If you cannot do the repair--shop around your area--most shops are going to charge 300 or more for this kind of repair.
When you consider the cost of the parts--if you can do it or know someone who can--you can save the set and a lot of money--This repair can easily be done right in your home in about 1 hour--I know as I have done hundreds of them---did two today.
The chips (with the back off of the set) should be on two metal heat sinks on the board on the far left---they will be facing the front of the set.
All that is required to get at them is to remove all the plugs on that board and the screws that hold it in and tilt it up so the bottom of the board is in view---you unsolder both chips (about 18 pins each) and remove the 2 screws that hold each to a heat sink.
With 2 new chips you put heat sink compound on the back of each--it is a white grease to move heat quickly from the chip to the metal, and solder both chips in----put the board back down and all the plugs back(I usually mark all of them so I know where they go) and turn the set on and see what you have...
Most of the time this repairs the set--go into the customer menu and adjust the convergence and you are ready for another 5-8 years of life---this is the normal lifespan of these chips.
If you need assistance or have questions let me know--I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 08, 2009
SOURCE: sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Posted on Dec 15, 2009
Testimonial: "very quick response "
SOURCE: I HAVE A SONY KP-53S65 PROJECTION TV AND I HAVE NO
A lot of times when that problem happens, its most likely not the lamp, when the lamp is the issue you can still hear a sound on your TV but no picture, most likely where looking at a problem with your power supply board or ballast, there might be something wrong with them that keeps from sending voltage to the lamp and audio parts, but on the other hand if you wish to change your lamp, depending on the model it can be on the back or sides of the TV, there is a little door with 4 screws that leads to the housing where the lamp is, you just need to pull out the housing and take it apart, its a actually a very easy task, you can have it done in like 5 min. an easier way is to purchase the whole lamp with the housing and just pull the old one and insert the new one in, less than 5 min!! If you have any other question don't hesitate on asking.
Posted on Mar 16, 2010
Testimonial: "TKS FOR YOUR ASSISTANCE."
Jul 29, 2010 | Sony KP-53S65 53" Rear Projection...
Jul 31, 2009 | Sony KP-53HS30 53" Rear Projection...
Jul 11, 2009 | Sony KP-53S65 53" Rear Projection...
Jul 05, 2009 | Sony KP-53S65 53" Rear Projection...
Feb 01, 2009 | Sony KP-53S65 53" Rear Projection...
Dec 27, 2008 | Sony KP-53S65 53" Rear Projection...
Dec 01, 2007 | Sony KP-53S65 53" Rear Projection...
Nov 12, 2007 | Sony KP-53S65 53" Rear Projection...
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
43 people viewed this question
