Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
Factory reset without remote
I don't have the native remote, I need to factory reset directly on the TV. is this possible?
I have a Philips tv model 32pack4507. It was working but I can't get it back on either manually or with a remote. Do I need part or new tv
Check batteries in remote. Or possibly a new universal remote. I just purchaced a RCA universal remote. Works better than the original factory remote, and easy to program to the correct code.
Apr 14, 2015 | Philips Televison & Video
Haier TV buttons usually don't work
does it connect to the internet? most new tv's now connect to the internet. through doing this it should do an update and possibly fix any issues you may have.
hope this helps
Jun 17, 2013 | Haier HL26R 26 in. LCD TV
The TV will turn on from remote many times and then won't turn on at all from the remote or directly from the TV itself so we end up unplugging the power which seems to reset the TV and then it
Having to unplug suggests a issue where the set is getting confused, if using any kind of box for signal or have a receiver in line remove power from all and after several minutes plug back.
Dec 17, 2012 | Vizio VS420LF1A TV
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
Have Emerson TV and lost original remote. Direct TV remote was programmed by Direct TV and working fine, then my son did something and it messed up. Bought a universal remote, able to get TV on and program...
There are control buttons on the side of the tv. Usually just on/off, volume, channel and menu. Go it menu using these buttons to navigate. Reset tv to default settings or sometimes called factory settings. This should get colour back. Download or read instructions on your remote and reprogram. Sometimes with modern universal remotes you need to program them through your PC with a specific application downloaded from remote manufacturer.
Nov 23, 2017 | Emerson CR202EM9 TV
My remote stopped working. I replaced batteries, nothing, bought a universal remote, followed directions nothing. Can the TV be the problem? Is there a factory reset on the TV?
it could be sensor on tv
try holding remote in front of a video recorder and if you push button on remote and view through video recorder you should be able to see the light blinking coming out of remote - if you see the light coming out of remote and it is still not working then the tvs sensor went bad
besides trying to unplug tv for a few minutes there is no reset for this issue
Mar 21, 2011 | Symphonic ST427FF TV
We need to get our tv back to factory settings, right now it is stuck in zoom mode and the picture is horrible. what do we need to do?
The reset can be done if you have the remote. Turn on the TV. Hold down the Reset button on the remote, then press and release the power button on the TV. The TV will turn off and then on. Once the TV is back on, release the Reset button on the remote.
If you need a replacement for the original remote, try the Sony Parts and Accessories store. Direct link for your model: https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&sessionId=anEScWjWuBo_v9WoEmM_PPp&modelNum=KV27FS100&searchText=KV27FS100&category=15&categoryName=Television . Alternatively: remotes.com has a substitute remote as well as used original remotes: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12881528939530&smodel=KV27FS100&brand_pn=SONY_KV27FS100 .
I hope this helps.
Oct 27, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
My remote quit working.
If ur direct tv remote have problems,or it defective.Talk to ur direct tv satalite provider to get another remote.U can try website like 1-800-Remotes factory original.To buy ur Proscan tv original remote.
May 03, 2010 | Proscan 32LB30QD 32 in. LCD TV
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Feb 26, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
