Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
SanDisk Cruzer Micro 1GB USB 2.0 Flash Drive
Posted by Chris Monger on
Mohd qasim ashrafi
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
WHAT PROBLEM ARE U FACING? KINDLY EXPLAIN IT CLEARLY!
http://www.tinyurl.com/9307740
Posted on May 15, 2014
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Posted on Jun 14, 2009
Anonymous
  • 185 Answers
SOURCE: Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Posted on Nov 07, 2009
Anonymous
  • 1112 Answers
SOURCE: SanDisk 8GB Cruzer Micro U3 USB Flash Drive
Hello Niz: If the stick is still usuable try downloading launch pad this usually works if the memory chip is still viable, You can get the download wizard from this site.
http://www.sandisk.com/sandisk-support/driver-download-wizard
Posted on Dec 15, 2009
Joaquim Martins
  • 1128 Answers
SOURCE: Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Posted on Jan 13, 2010
Anonymous
  • 3153 Answers
SOURCE: Sandisk Problame Unable To Open.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Jan 21, 2010
My 8gb sandisk cruzer does not light up anymore and is not recognized.
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
2helpful
How to remove write protection from Sandisk micro cruzer thumbdrive?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format thumbdrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
2helpful
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
Top SanDisk Electronics - Others Experts
k24674
Ekse
Joaquim Martins
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
