HOW DO I DESIGN AND PRINT LABELS ON MY TLP 2742 . IT IS ALL CONNECTED TO MY COMPUTER AND INSTALLED
SOURCE: Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
SOURCE: TLP 2742 not printing
Go to printer properties, advanced - tools - commands
and enter: ^DEFAULT
This command reseys the prntr
Cheers
SOURCE: 2742 no longer stops printing when ribbon runs out
its probably set for direct thermal in the driver, you need to set it for thermal transfer in both printer defaults and printer preferences
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using. If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands:
q456
Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
