It connects to the computer and the backup runs. Then it does nothing else. Claims to be running, but no download are happening. This used to take seconds, but it's been 20min.
SOURCE: GArmin Nuvi 360 - bluetooth not working right
I had the same issue, prior to downloading the update. So I downloaded the update and when it asks you if you want to check for further updates for this device, select yes. There, you'll find the bluetooth update. After I installed it, the device seemed to work perfectly. My garmin nuvi 360 has yet to disconnect from my phone, and it's been several hours since I updated.
Best of luck to you!
jonathan
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
SOURCE: Nuvi 205W keeps rebooting.
Here is the solution
touch the screen in the right bottom and turn the device on keep the screen pressed. when it asks to reset data select yes
SOURCE: Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html
Download and unzip the software, plug your garmin in the USB and start
the updater.exe program. It gets you started again. Later on you can
use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
SOURCE: garmin 1300 stuck on maps loading frozen
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
