Question about Compaq Presario C700T Notebook
Broken screen on compaq presario c700 wont connect to tv via VGA cable, I also have compaq presario cq57 - this one connects no problems
SOURCE: Need Sound Card Driver (Compaq Presario C700)
hi firend
here is link
Audio driver from the link below .
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Do not click on the link. Please copy the link and paste the link at the
address bar of the browser. Next hit the enter key.
k
Installing this driver may result in an error. But continue with the
following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant
High
defination audio entry and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from
the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp35940 folder and the double click the
(WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file,
click open and Continue with the onscreen instructions.
Similarly install Modem Driver:
Posted on Apr 25, 2008
SOURCE: broken headphone socket on compaq presario c700
It can be replaced as it is most likely a standard part. The problem is that 1) it is a surface mounted socket and 2) the entire laptop must be dis-assembled to get to it. This is not a repair I would recommend to a novice. Ask around for someone that can work on surface mounted parts and see how much for the repair. The part should not be more than $2-$4.
Dan
Posted on Jun 04, 2008
SOURCE: download sound driver for compaq presario c700 with product number GS096PA#ACJ
i want sound driver for compaq presario C700 laptop
model no C734TU
Posted on Sep 19, 2008
SOURCE: automatic detection of lcd projectors to my hp compaq presario c700
try to set your resolution on your laptop, it have an option for proyektor setting, i've done it but now it displyed not horizontally but vertically, do you have any solution??
Posted on Nov 24, 2008
This steps only for compaq presario c700.....
don't update your laptop.....kindly turn off all windows update...
uninstall
all audio, hd modem, and UAA bux driver for high defination driver in
system device....restart your lpatop..go to hp.com and search following
no. for modem driver-(sp33442), for audio driver(sp35270), for UAA
driver (sp32395), download and install...
and install drivers follow these steps:
Open device manager and right-click on Audio device on High definition Audio Bus.
Select Install from a list of specific location (Advanced) Click Next
Select Don’t Search. I will choose the driver to install.
Select Sound, Game & video controller from the list of Hardware type
Click on Have Disk
Click on Browse and navigate to C:swsetupsp35270 and click on .ini file OK
Click Next
It will give you an update driver warning message. Click on yes.
It will start installing the driver
Click on Finish..
follow these steps to all drivers install.
bye,,,,,,,,,,
Posted on Apr 09, 2009
