Question about Microsoft Windows XP Professional
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
Posted by benjamin516 on
rmoughon
    New Friend:
    Problem Solver:
  • 7 Answers
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Posted on Jan 30, 2014
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: NTLDR missing while clean install
Well Bart CD that everyone downloads has some nice utilities on it, some free some not.
You have to be carefull using such utilities as they can cause more harm then good...
You now have to reinstall windows before you can apply sp3. Sp3 is not bootable and bart CD doesn't have windows install of any kind on it... Reinstall windows with your disc then browse to your cd and double click on sp3 to update...
Hope everything works out now....
Please rate this solution if it helps... Thank You...
Posted on Nov 03, 2008
Anonymous
  • 57 Answers
SOURCE: NTLDR Missing, Press Ctrl+Alt+Del to restart
What happened is when you changed the drive letters you switched one that should not have been changed.... You need to change it back so the original C: is C:
Because the original NTLDR file was on the C: drive which is the Windows XP Boot Loader and when you swapped it it couldnt find the ntldr on the new C:
From my opinion the only way to switch it back is to reinstall the OS onto the drive you want to be C:
Posted on Dec 18, 2008
halbrook
Liza Halbrook
  • 560 Answers
SOURCE: whenever i switch on my system, it displays NTLDR MISSING.
looks like you have a corrupted MBR, this will fix the problem if its MBR
1. boot to Windows XP CD
2. Choose the Recovery Console
3. Type your admin username
4. Type your admin password if you have one set
5. Type Fixmbr
then restart and remove CD
10. Load windows !
11. Enjoy !
Posted on Nov 10, 2009
Anonymous
  • 39 Answers
SOURCE: How can I solve this problem, "NTLDR is missing"?
Pleas follow this steps to solve this problem:
1. Insert your Windows XP CD into your computer.
2. When prompted to press any key to boot from the CD, press any key. When you see the Windows XP setup menu press the "R" key to repair Windows.
3. Log into your Windows installation by pressing the "1" key and pressing enter.
4. You will then be prompted for your administrator password, enter that password.
5. Copy the files below to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. if your cd or dvd drive is F: then replace "E:" with "F:"
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7. Once both of these files have been successfully copied, remove the CD from the computer and restart your computer.
Posted on May 12, 2010
Anonymous
  • 172 Answers
SOURCE: i have lost NTLDR and
Vista doesn't use ntldr. If it's being called for, that means the mbr was
not overwritten to point to Vista's bootloader and it's still looking for
XP's. Check the system BIOS for a protection setting that disallows writing
to the mbr (bootsector antivirus protection is a common term for it). This
needs to be disabled during setup or Vista will not be able to alter the mbr
correctly.
Thanks for choosing Fixya
Sandeep
Posted on Mar 21, 2011
NTLDR Missing or what?
You would have deleted the small kb file which contains the information of NTLDR from C: drive , Just download hire boot from net and boot it the first option in that you will see FIX NTLDR
Jan 21, 2014 | Dell Computers & Internet
My laptop inspiron 1501 says ntldr missing
Hi ... The 'NTLDR missing' means that windows NT Loder file is missing so OS can't boot.
1- Check that you haven't any usb key or something like connected to ur laptop.
2- Make an update to ur OS by using installation CD and choose update option to re install NTLDR file.
About BIOS password you must remember pass or who make it to solve this problem.
I hope this can help you ;)
Dec 26, 2017 | Dell Inspiron 1501 Notebook
Toshiba dynabook ss 1600 80c/2 ntldr is missing ctrl+alt+delete to restart
To repair missing NTLDR or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Nov 17, 2012 | Computers & Internet
When i switch it on it displays ntldr and to press control alt and delete to restart
ntldr is missing?
If so, you need to restore it from installation disk (if you have the disc and external cd/dvd-rom).
Let me know if you don't have any of them.
Apr 29, 2011 | Acer Aspire One Netbook 8.9" Notebook
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
My Satellite A40/A45 Series won't boot up.
If NTLDR is missing, you will need to do one of two things:
1) follow this link and follow instructions to create a NTLDR boot disc and get back up and running
or
2) boot to Windows CD and repair Windows installation
Hope this helps - remember to rate :)
Sep 25, 2008 | Toshiba P000392200 - Satellite A40, A45...
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Microsoft Windows XP Professional Logo
306 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
