Question about Netopia Computers & Internet
Need password Netopia Model 3347-02
Posted by Darlene Drecksler on
  • Netopia Master
  • 7,733 Answers
"Try http://www.fixya.com/support/r11153882-general_routers_reseting"
Posted on May 29, 2014
Do these have a wps button?
Honestly, no idea. If you don't have a manual with the MODEL you can try to look for the proper one,
I got some links, maybe one is yours:
http://www.netwood.net/support/manuals/Netopia-3347W-ENT_qsg.pdf
http://www.netwood.net/support/manuals/Netopia-2247-62-User-Guide-US-EN.pdf
http://videos.cctvcamerapros.com/pdf/netopia-router/Netopia-Router-Manual.pdf
There are more....
Now, take note that WPS is too easy to hack. Read some about this issue:
How to Hack Wi Fi Breaking WPS PIN to Get the Password with Bully
And read more about theme...
Aug 26, 2015 | Netopia Computers & Internet
I need help to set up my Iphone with Wi-Fi access. Where and how to find my password for Netopia router?
Netopia routers use as default the following passwords:
1234
admin
password
Sep 20, 2014 | Computers & Internet
Router rejects password
router admin password can be different from wireless password.
this page should help:
http://portforward.com/default_username_password/Netopia.htm
good luck
Nov 22, 2013 | Netopia (3347NWG-ENT) Router (3347NWGENT)
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Oct 24, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
Netopia router test page keeps poping up while i'm on line
Reset your netopia by holding the reset button in for at least 30 seconds.
Reconfig your netopia again.
You do this by opening internet explorer. It will say "Page cannnot be displayed"
type 192 168.1 254 in the address bar (where you normally type www)
the username is admin
the password is the serial number on the bottom of the netopia
click on configure
click on quickstart
put in your userID like [email protected]
and your password
click submit at the bottom
and then click the yellow triangle dealie at the top right
click save and restart the database
when it comes back on in a few minutes, you'll be online
If this doesnt resove the issue, then your firmware is messed up and its time to swap out the netopia.
spin
May 29, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Aug 29, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Unlock netopia 2247 router
If your talking about the password for the router user interface that is not working that resetting it again using a pen or a paper clip just press and hold the reset button for 30 seconds then that should bring your router to its default settings with the default username and password.
May 06, 2008 | Netopia 2247NWG-VGx Wireless Router...
Computers & Internet Logo
47 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
