RCA D52W19 52" Rear Projection Television Logo
A
Anonymous Posted on Jan 29, 2014
I have a RCA D52W19 TV. The Tv started to shut off upon start up. Now it will not start up. you can hear 3 chirps when the power cord is plugged in. Any ideas?
5 Related Answers
Michael Borelli
  • 979 Answers
  • Posted on Dec 12, 2008
SOURCE: Need to know how to install a flyback in 2004 52 in RCA tv.
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
jamie
  • 1810 Answers
  • Posted on Feb 16, 2009
SOURCE: rca tv wont come on at all
there is an inherant problem with rca tv's
they are not vented properly as far as im concerned
right in front of the fly back is a small part in mine it is grey i think it's a resister
when i took the back off i saw that it was sparking on 1 end ( wholy chit ) scared the **** out of me
if your chip is sparking try this fix if not turning on or no pic look inside and look for burns vthere a tell tale sign of over heating
what i did was crazzy but it worked
i took the stupid chip off by pulling on it what the puck it was screwed any how
then took it to my local electronics store they tested it and told me it was fine just had to but a new 1 since i broke a pin on 1 end
nothing grinding down ends of the case and adding some wire to the pins so i had somthing to solder to
the i re soldered the thing back to the board dam thing was trickey but as long as you are smart and gentl and for god sake un plug the set there is 600 volts inside if not more that can kill you near this chip
it now works fine my 52 inch tv has cost me $7.00 in gas and about 3 hours of time
what i noticed was that the chip over heated at the solder joint and burnt the hole bigger so i soldered and wired to the next conection and re soldered it carefully i did not remove or un plug any thing i just remeoved the board from it's slide mount and carrefully tiped t of only poping 2 conections witch were easy 2 put back on the tv is great it just hates running for 6 monthes at a time hell you shut off your $500.00 computer every once and a while dont you ???
then why would you not shut off your 2000 dollar tv every day
well hope this helps all or at least some of us who cant afford a high priced repair person to show up and tell us it will be 3-400 to fix but they will give us 50.00 for the old chasie and fix it and re sell it for 500 in a refurb tv store like factory direct in canada
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 30, 2009
SOURCE: Need Service manual for a RCA D52W19 Projection TV
You can get one at the following link. They email then within minutes. Heres a link to the correct Manual as Thomson makes those TVs for RCA
http://servicemanuals.vstore.ca/product_info.php/pName/itc222/cName/thomson
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Sep 07, 2009
SOURCE: RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
salt56
TV Doctor
  • 373 Answers
  • Posted on Jul 15, 2011
SOURCE: I REPLACED RCA D52W19 CAPACITORS
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Testimonial: "YES SIR YOU ARE RIGHT YEAH THANKS FOR ALL THE HELP"
1helpful
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
BIG SCREEN rca d53w19, where are the fuses????
There is one fuse if you look in the rear of the set on the left side follow the power cord as the cord plugs into the Main filter board which has the fuse. Its located right next to the power cord on the right side of that board
My tv has a dinosaur in it.
Its a raptor most likely. But seriously, when these RCA TVs go into shutdown or fail to power up, they will try 3 times to re-establish operation. Your problem can be caused by a number of circuits. The power supply itself may be bad or the high voltage/ deflection circuit. You can visually inspect the circuit board. Some failures in these TVs will cause obviously damaged components like burned resistors and the like. The problem here is that most anything that will fail will cost some serious money. Expect to spend $300-500 to repair it or consider replacing it.
michtech
Rca hidef tv
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
2answers
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Power Surge?
Sound? audio from station.. or noise this set is going into shutdown. the processor is seeing a problem with its safety cuircits and shutdown the set it will try to restart the set 3 times and then lock it down. it can be many things. the processor has an error log.. technician can get in and read codes.
My RCA TV turned itself off and started making chirping noise
You have poor solder connections these sets are famous for this! Solder Flyback transfomer pinns this should fix it.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
