Question about Maytag Dryers
Maytag Centennial Dryer (MEDC400VW) not drying properly
We bought a house with a brand new Maytag Centennial dryer (MEDC400VW). The house had been empty for two years, so this would not be under warranty. It takes 2-3 cycles to dry a standard load of clothes. We keep the lint trap clean and we can feel heat coming out of the vent outside of the house. The clothes are warm/hot when they go through the first cycle, just not dry. It doesn't matter if it is on timed dry or automatic dry. It is tumbling. I have worked on dryers before (Whirlpool, changing heating elements, etc.) Any thoughts about where to start?
Posted by Philip Weinrich on
Melissa Martin
    Master:
  • Maytag Master
  • 753 Answers
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Posted on Jan 30, 2014
  • Melissa Martin
    Melissa Martin Jan 30, 2014
3 Related Answers
Anonymous
  • 619 Answers
SOURCE: My maytag centennial dryer is getting too hot and
Exhaust problems are the only thing that will cause this. Check to make sure the exhaust behind the dryer is going straight out without alot of bends. Also no exhaust should be over 20 ft to the outside. Ther is a tip on how to clear house exhaust in the tips section. Just type dryer to long to dry and should take you there.
Posted on Jun 02, 2010
Donni Steen
  • 687 Answers
SOURCE: my dryer is not drying properly. It takes 2 cycles to get clothes dry. I have cleaned the lint traps and vents but that did not seem to help. Is it worth fixing or is it time to get a new dryer?
You need to check the blower compartment to see if there is a restriction in airflow, also check the thermostat on the system as well. Where the stat is located is brand specific. Check your wiring diagram that is typically stored somewhere near the electronics on the inside in an envelope.
Posted on Apr 18, 2009
Anonymous
  • 1122 Answers
SOURCE: dryer takes too long to dry
if you have a top lint filter turn the dryer on pull the lint filter out and put your hand in it and see if you have good suckion,if not you still have a clog-mike
Posted on Feb 11, 2010
Testimonial: "Thanks for the advice. After taking the dryer apart and checking everything, I found a huge clog of dog hair inside. It's working like new now."
Replaced heating element. Dried one load of clothes and element went out again. What could be the problem?
The likelihood of a second element failure is very remote, unless the element suffered some damage, like bending or chipping.
It seems more likely that you have a thermal limiter that is opening. There can be two or more, and they are in series with the power to the element.
Unplug the dryer and test the thermal limiters.
Another area to look at is the control switch. Long story short, there is a ton of current going to the element. The contacts in the switch can carbon up and overheat.
Dec 10, 2014 | Maytag Centennial MEDC400VW 7.0 Cu. Ft....
Will not start
Please check door switch and wiring
Mar 23, 2014 | Maytag Centennial MEDC400VW 7.0 Cu. Ft....
I have a maytag medc400vw it is still blowing cold air
29 inch dryer with the filter in the top with a heat problem. I fixed a few of them in my day. Here are 2 different dryers with hard to solve problems:
On this next one I do an autopsy on the timer which I suspect is the problem:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 19, 2012 | Maytag Centennial MEDC400VW 7.0 Cu. Ft....
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
My centennial dryer (model medc400vw) won't start
I would bypass the door switch and see if it starts.
Aug 29, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
My maytag centennial dryer is getting too hot and not drying my clothes. I always empty the lint trap, and have checked the vent going outside. The airflow seems to come out fine, but the air is too hot...
May 31, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
Heat works but the motor does not engage. No
The belt may be off the motor pulley.
Jul 05, 2009 | Maytag MEDC400V Dryer
Dryers Logo
955 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
