Marshall Amplification Marshall MG412A or MG412B 120W 4x12 Guitar EXtension Cabinet Angled Logo
Steve King Posted on Jan 29, 2014
Need to know how to wire a marshell speaker cab
2nd hand possiable messed with.want to make sure is done correctly
godzai
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 31, 2014
godzai
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
1193
Points
22
Here you go.
http://www.jumbosunshade.com/swd01.htm
make sure to figure out what the ohms are of each speaker and how it is currently wired before messing with it. Make a plan, then act.
2answers
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
How do you change from 4 to 8 ohm output on a phonic 1860 mixer
Stereo and bridged mode selects automatically. Stereo mode gives 4-16 ohms per side. Bridged mode is only from 8-16 ohms. This impedance match is created by the combination of speakers you use. If you link any speakers, the wiring is usually going to be in parallel because of the sockets wiring in the cabs. Any time you link 2 speakers in parallel, it cuts the impedance in half. Remember that in bridged mode, do not link 2 8 ohm sets together because this will create a 4 ohm circuit which it will not allow. This can only be done in stereo mode. It is ok to use speaker combinations of higher impedance, but never go lower as it would cause damage to the power amp.
Apr 03, 2013 • Music
3answers
Loud Speakers only have 1/4 inch inputs
Get the Speakons to 1/4" cables. If you're concerned about grounding, make sure the amp is turned off before plugging or unplugging the speakers.
May 02, 2017 • Music
[23:05:39] Sharon Levit: hello! i have aproblem. iwll be glad if you can help me! so here is my problem: i bought a marshell 15 MG amp few days ago and this annoing buzzing problems. every time when i...
Make sure you are using this on a three wire grounded receptacle. If you are on an old two wirepower system, have a ground installed in the receptaclel you are using. If you are on a grounded circuit, then exercise your warranty for repair/replacement.
1helpful
Somehow have managed to remove wires from drivers (while trouble shooting svt 410 hlf cab) while not labeling them properly for reinstall. so far have not been able to locate a wiring diagram for inside...
Most schematics won't even have any colors listed... so let us have you try this:
Find a system ground someplace like the sleeve of a 1/4 inch jack... Using an ohmmeter check for continuity to the available wires that are disconnected. ASSUME that those showing a low resistance will go to the "-" terminals of the drivers. If you have say a black and red... expect that the black will be one of the grounds... often the red then will be the (+) of the woofer. If you have whites and yellow... OFten the white will also have continuity to ground and be the (-) for the tweeter and the yellow then to the (+). Now since your speaker has 4 woofers we need to be careful to wire then correctly to get the 4 ohm impedance of the cab. IF each woofer is 4 ohms impedance, then we need to wire them in series-parallel. The shell of input 1.4 inch jack will likely go to black wires... two of the speakers will have their (-) terminals connected to these. The tip of the 1/4 inch jack will probably connect to one or more red wires. These will connect to the (+) terminals of the OTHER TWO woofers. Next one of the available (-) with no connections will tie to the (+) terminal of one of the first two woofers. SImilarly the remaining (-) terminal of one of the woofers will tie to the last (+) terminal that is vacant. Note the + of the horn will tie probably to the High level pot and this will tie to the crossover someway.
Here is a site with general schematics.
http://www.bcae1.com/spkrmlti.htm
1helpful
2answers
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
My Bugera 1960 stopped working in the middle of a rehearsal. I was playing at about level 3/4 in the 1st input of the 2nd channel. The amp was connected to a Marshall 4x10 bass cabinet. The connection of...
Wiring harness connector to the power tube section is fried. A common problem with all bugera amps and many other companies also. A cheap fix. You can order the part you need from newark.com or call 1-800-4newark the part number is sku#85c0290 mfr#09-91-0500
I want to know how to wire a speaker
Weather of not you can use this speaker as an extension cab depends on a number of things. First, what amp are you planning you use for it? What is the minimum resistance for this amp (2ohm or 4 ohm probably). Second, what is the primary cab you are using ans what is the resistance on that? (2ohm, 4ohm or 8ohm).
Is there just one speaker in you proposed extension cab? The goal is to have all the speakers wired in parallel without lowering the resistance to a point that will damage the head. So if your amps minimum resistance is 4ohm then your cabs will have to both be 8ohm, running in parallel the overall resistance will be 4ohm.
Oct 04, 2008 • Music
Top Marshall Amplification Music Experts
matt martin
matt martin
Ngoro
ADMIN Eric
ADMIN Eric
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
