Electrolux EW1200i Front Load Washer / Dryer Logo
Question about Electrolux EW1200i Front Load Washer / Dryer
My electrolux dry when i press start light on the panel goes on and it seems like it want to start but it does not.
When i press the start button i hear a humming but it does not start spinning. The lights on the control panel goes on but the dryer does not start.
Posted by Evelyn Almanzar on
tostrokesmok
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 130 Answers
If the voltage going to the dryer is correct it is probably a bad start capacitor on the motor a bad time will also cause it not to start one more thing can think of on the door there is a door safety switch bypass the door safety switch and see if it will start
Posted on Jan 29, 2014
  • Lisa Ubachs
    Lisa Ubachs Jun 07, 2022
    Thanks it was safety switch
Lisa Ubachs
Electrolux dryer replaced blower wheel now when I push start it switches to cancel
Posted on Jun 07, 2022
4 Related Answers
mnwarfield10
mark warfield
  • 453 Answers
SOURCE: Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Posted on Dec 30, 2009
Anonymous
  • 2382 Answers
SOURCE: The washing machine Electrolux 1087
Hi, if the washing machine stops in the middle of a wash cycle, the first step that should be taken is to perform troubleshooting steps to determine the cause of the problem. After the source of the trouble has been established, it can be resolved in most cases by continuing the troubleshooting process.
  • Make sure the lid is completely closed. Certain parts of a wash cycle will not start if the lid is not closed.
  • Check the load to see whether it is unbalanced. If the washer gets off balance, it may stop in the middle of a cycle. Redistribute the clothing so that it is evenly balanced around the drum.
  • Make sure the hot and cold water faucets connected to the washing machine are turned on fully. If the washing machine is not getting enough water, it will not be able to complete the cycle.
  • Inspect the drain hose for clogs or obstructions. The washing machine may stop if it is unable to drain water properly. Check the drain pipe that the hose feeds into for clogs or debris.
  • Check the house's circuit breaker panel or fuse box. The circuit may have been tripped or a fuse may be blown. Replace any blown fuses and reset any tripped circuits.
If after doing all these and the problem still persist, you have to call in a tech to check it out because there is no way to reset the Electrolux 1087
Posted on Dec 20, 2010
Anonymous
  • 10319 Answers
SOURCE: I have an electrolux top
by clicking onto the provided website below you can download the manual for your washer explaining how to correct your problem. It has a chart toward the end which explains what to do
It would be too long to type everything in myself
http://www.google.com/search?q=electrolux+top+loader+model+EWT+806+it+will+not+spin+dry+The+lid+lock+light+is+blinking+and+it+keeps+beeping+&rlz=1I7GPCK_en&ie=UTF-8&oe=UTF-8&sourceid=ie7
Posted on Aug 06, 2011
Anonymous
SOURCE: I have an Electrolux EWD1477.
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Posted on Aug 30, 2011
2answers
I need help, my Electrolux dishlex DX302 is having issues. Th lights for the type of wash and the time panel are flashing constantly. The program button doesn’t work and it seems to reset every time I try...
These dishwashers have a control panel lock feature that allows you to lock the control panel to prevent kids from activating the unit.
To toggle lock/unlock mode, open the door, press and hold the AIR DRY button for 4 seconds.
How do I turn off child lock on Electrolux dryer
For some Electrolux models, icluding the EDC2086PDW, the child lock (control panel lock) is toggled on and off by pressing and holding the Time and Wool Load touch pads together. Hold the buttons until you hear the beep or the indicator light goes off. (The dryer needs to be on for this to work.) On the EDH3498RDL, the two buttons are the Time and Anti-Crease. On both of these models, the two buttons are the left-most pair of a set of four buttons to the right of the LCD screen.
The much newer EDH3498RDL uses a different Control Lock method. Press the Options button repeatedly until the LED next to Lock is let. Then press the adjacent Set button. The Lock option is in the column just to the left of the Start button.
Please add a comment with the model number of your dryer to get the procedure for your unit. I hope this helps.
Remove child lock from Electrolux front load dryer model # EFDE210TIW
To disable the child lock (control panel lock) on the Electrolux EFDE210TIW, press and hold the Dry Time and Wrinkle Release key pad buttons until the indicator light goes off. These are the two buttons to the right of the LCD screen. You will need to hold the buttons for several seconds (usually between 3 and 10 seconds depending on when the dryer was manufactured).
See page 11 in the user manual. The manual is available on the product page: https://www.electroluxappliances.com/Washers-Dryers/Washing-Machines/Dryers/EFDE210TIW/ . The direct link to the English version of the manual is currently http://manuals.electroluxappliances.com/prodinfo_pdf/Webster/136936001en.pdf .
I hope this helps.
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
2helpful
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
1helpful
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
1helpful
Is there a reset for fdb1100rhs dishwasher
I can tell you the reset sequence for the whirlpool dishwasher. I believe frigidaire are made by the same company (Electrolux).
Press Heated Dry, Normal, Heated Dry Normal in sequence on the front panel within 5-6 secs. All lights on panel should light up. Press the cancel button to exit.
Hope this helps.
2answers
We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
