SOURCE: How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
SOURCE: I have a sharp ar-m257 copier. my copies were
There are a few thing's > have you cleaned the optic's > clean the primary charge unit in the drum unit > how old is the drum & developer? Also, is the copier calling for for "Maint's Req"
SOURCE: Its a New Sharp AR-5316 Printer and it is showing
# interrupt 0 interrupt press 16 press printkey
SOURCE: IS there a reset code for a Sharp AR-507 copier,
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
