Can jump off starter but still wont start. help!!
SOURCE: I have a 03 GMC Envoy and just went out of
WELL CHECK CABELS FOR CROSSION VERY COMEN IT TAKE THE AMPS AWAY CUT THE HOUSEING BACK NEAR BATTERY SEE HOW BAD THECORSION AROUND WIRE IS THIS CAN MAKE LIKE BAD STARTER OR SILNOID IF YOU DO NOT FIND ANTHING THERE MAKE SHERE ALL GROUND WIRE ARE CLEAN AT THE SERFACE CONTAC BUT IT COULD BE BAD SLENOID BUT IF IT DOSE AGAIN SEE HOW THE VOLTAGE IS WHEN YOU TRUNE KEY TO START THE CAR AT SMALL WIRE AT SILNIOD MAY BE BAD IGNTION HOPE THIS HELPS
SOURCE: 1993 sierra gmc truck wont start... speedometor
If your starter has 2 or more small wires on it you may have switched the terminals. If you have a separate starter relay you can bypass the relay with a jumper cable and send 12 volts to the starters only main cable. It should crank, have it in Park (Auto) or Neutral (stick shift). If the starter does not crank bypassed then the only thing missing is a good ground. Use a pair of jumper cables and try grounding the starter case and connect the cable to a good ground. With the gauges dancing usually a bad ground is the reason, so the jumper cables will help with that problem too, at least for test reasons.
If you had the old starter tested, then you know it was the first problem. But if the old starter was not tested your problem could be a bad starter relay, an ignition switch,or finally a bad ground. Check the grounding of the remote starter relay, check for a plug-in connector off the end of the steering column for corrosion.
SOURCE: 03 GMC envoy..wont start all
Try giving the starter a whack with a hammer or end of broomstick if it tries or goes, replace the starter
Testimonial: "actually the soleniod.or maybe just the terminals to it.they were a little corroded.i loosened the nuts and sprayed and cleaned them..now it works."
