Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Viewsonic 3252W 32"
This TV is the 32" version of the N2750W.  I have had this TV for about 5 months and it won't turn on now.  I have it hooked up to a surge protector strip and have tried plugging the TV directly into the wall outlet.  Checked all the hookups and it still will not turn on either with the remote or using the on/off button on the TV.
Posted by Ftlgh on
  • stobiemas Nov 06, 2007
    I have a Viewsonic N3250w that no longer powers on. The unit started shutting itself off on occasion. When powering the unit on, the power LED would illuminate for 5-6 seconds, then turn off. No video would show during this time. No video, no LED at this point.
    Anyone have an idea of what part I may need to fix this issue?
  • Anonymous Apr 18, 2008
    My 3252W stopped responding to the remote control. Two new remotes didn't work either. ViewSonic warranty service screwed me around for 6 weeks, lying and not responding. They now want me to ship it from TX to CA at my expense. You don't want to ever have to deal with ViewSonic.
Anonymous
You need to find a power supply! You can find them on Ebay from time to time. Just enter your model number in the search bar and see what pops up. Good luck! :-)
Posted on Mar 07, 2008
Anonymous
Buy another tv. All parts no longer available. and all the board can't be rebuild. Gabage.
Posted on Dec 05, 2007
Remote codes for the Viewsonic N2750w for Samsung cable box
The code number for my Samsung remote for a Viewsonic TV is:
210
Jul 02, 2014 | ViewSonic N2750w 27 in. HD-Ready LCD...
Remote codes for the Viewsonic N2750w to work with Samsung cable box
210
I also have the Viewsonic N2750w. I have power but when I turn it on I can very briefly see the screen and picture then it goes black, The power indicator always stays green, This happens when I hook my HP...
Follw the link below and chak out page 6 for control butons. fumction and then look at page 19 to check that you have the correct video surce type selected
https://www.manualslib.com/manual/186651/Viewsonic-N2750w.html#manual
Sep 24, 2017 | ViewSonic VA702b 17" LCD Monitor
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound)
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/pdf/UX8623D.pdf - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector. http://www.viewsonic.com.au/support/manuals/files/LCd%20TV/N2750w%20User%20Guide%20English.pdf
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
I have a fine red vertical line running from top to bottom on my ViewSonic 32 TV. How do I eliminate the line?
There is either a bad color tube or bad cap that will need to be replaced. The caps are about $4 each and can easily be soldered.
Jul 02, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
I can't find a way to turn off internal speakers when using external audio amp with N2750w.
just turn the tv down to minimum volume i don't think there is a way to turn them off
Jun 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Problem with picture
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
Jan 18, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic 32" TV
You can open it when remove all screws at the back, from the stand also (under the TV).
Then carefully remove the snap-in shell ( front and back). TV is one compact part and plastic shell is snapping ( front and back) + stand, on the screws.
Nov 25, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
453 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
