Question about Dell Inspiron 1501 Notebook
Change dell inspiron 6040 function keys - Dell Inspiron 1501 Notebook
5 Related Answers
Justin Losh
  • 36 Answers
SOURCE: FUNCTION KEYS ON DELL INSPIRON 8000 DON'T WORK AFTER INSTALLING W
There is no driver required to use the function keys. You just need to use the function (fn) like a shift key. Hold the function (fn) key and then press the according function key.
Posted on Mar 21, 2009
Anonymous
  • 453 Answers
SOURCE: reinstall factory settings using Functions keys on a Dell
Turn off the system.
Turn on and press Ctrl+F11 immediately. It will take you to the DELL Complete PC restore which will help you restore to factory settings.
Posted on Sep 06, 2009
SOURCE: Dell Inspiron 8600 now missing the battery meter
Click here and click the link to download all on the upper right hand side of the page. Instruction are embedded in the page and the download themselves for each individual download, including what they do and so on...... Unzip and installation of all these is highly recommended to restore your system back to factory functionality......i assure you that the battery meter shortcut is not the only function missing from your system.....you just haven't found the rest yet, and may never need them for that matter, but still i do recommend installing all the downloads that are available for your device, and don't worry, if there is anything that needs to be overwritten during installation, let if overwrite...you'll be just fine..... so there ya go, sry i cant walk you through the whole process but there wouldn't be enough room for me to spell it all out on here.
GOOD LUCK AND PLS RATE THIS POST!! :D
Posted on Oct 08, 2009
byteguy
Art Ellison
  • 2229 Answers
SOURCE: dell inspiron keyboard issue?
There is a keystroke combo that enables or disables those keys.
They should work. Can't remember the keystroke, but it's a FN plus one of the keys--should be a symbol on the keyboard.
Posted on Dec 12, 2009
Anonymous
SOURCE: Function key stuck on Dell Inspiron 700m
fn + F3
Posted on Apr 19, 2010
DELL Inspiron Laptop n Series Key Pad not working
Hi
It sounds like you have to change the key board, its either a software or hardware problem and if you re-installed windows and you have the same problem then the keyboard has to be changed.
cheers
Nov 28, 2012 | Computers & Internet
Function keys
Enter BIOS by pressing F2 or DEL or F10 (try all), and see if there is a Function key option. Change it, save and exit. If everything else is working fine, you can also try to push and hold Fn key and then press a function key.
Nov 19, 2012 | Dell Inspiron 1501 Notebook
I have dell inspiron 15r ( n5010 ) this fn key are not working
The default behaviour of the Fn Key of Dell Inspiron n5010 is as Multimedia Controls, which can be changed from the BIOS by setting the behaviour of the FN Key as Function.
To do so: -
1. Restart the laptop and Press F2 to enter into BIOS Settings.
2. Locate Fn Key option and set it for Functions
Hope it helps! Good Luck!
CreativeTECH
May 27, 2011 | Computers & Internet
Hello, My function key on Dell Inspiron M5030 doesn't work; could you help me solve the problem? Thank you.
http://support.dell.com/support/edocs/systems/insm5030/en/sg/sg_en.pdf PAGE 30
You have to go to (winkey)- xto get to the Windows Mobility Center and in the function key row, select Function Key instead of Multimedia key. This should reverse the Fn problem.
Dec 29, 2010 | Dell Inspiron M5030 Laptop
Dell inspiron keyboard issue?
Dec 12, 2009 | Dell Computers & Internet
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
Reinstall factory settings using Functions keys on a Dell
Sep 06, 2009 | Dell Inspiron 700M Notebook
How to turn the monitor off?
go to control Panel, Hardware and Sound and then select Power Options. There are several plans to choose from or you can create your own Power Plan. Choose when you want the display to shut off but make sure the "Put the computer to sleep:" is set to "never". The save the changes.
Sep 02, 2009 | Dell Inspiron 1525 Notebook
Mar 20, 2009 | Dell Inspiron 8000 Notebook
Dell Inspiron 1501 Notebook Logo
35 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
