Check all the folders, often e-mail clients do not import e-mail directly to your inbox and alike, they will create a fresh folder alongside your inbox, perhaps call "recovered mail".
thanks but yep checked them all..nothing new :( . I have used this transfer tool before on my previous pc and it worked fine. All the folders and emails were imported ok..but this time I'm not so lucky
All I can recommend off the top of my head in that case is try exporting the mail again using the transfer tool, and then import again.
I've tried several times...including unistalling incredimail then reinstalling and retransferring...I thought it might be something in windows 8 or the upgrade to incredimail 2.5 from version 2.0 preventing me from seeing stuff as the set up in incredimail 2.5 is different...shows each email account in a separate inbox rather than all in one. I bet its something simple but I just cant think what to try next..all I really want to be able to recover is the 'sent mail' as all the incoming stuff is still on the virgin media server which I can live with. Thanks for your help anyway it is appreciated.
SOURCE: CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
I also have the same problem. I've tried all the above plus some added info. The floppy still works when I swap it with the DVD. Occasionally it works for a short time right after a hard boot but soon after it appears to uninstall. I have searched the net for answers to this problem without success. I tried the registry correction without avail. There has been some online comments that the problem appeared after an auto update from uSoft. I believe the problem is software or firmware related.
SOURCE: Parallels Desktop
Hi toy4runner,
Did you check the permissions of the folders that need to be openend by parallels to get to the file? (just select the folders one by one and for ech of them press apple - I and check the permissions section of the information pane. Chnaces are Parallels is trying to access a folder but doesn't have the right permission.
If all seems okay, check this:
http://kb.parallels.com/en/4680
Hope it helps
SOURCE: R40 Thinkpad CD drive
I also have an IBM R40 with a combo drive that showed the same symptoms. I switched the drive with two another two which I can assure that work 100% correctly, and the same problem happens. First the drive wasn't detected some of the times, or it got randomly "disconnected" while the laptop was on. Nowadays (about 1 year ago), the drive never gets detected, not by the BIOS or by the operating system (Linux, but also tried on Windows), even so, If I don't keep the drive disconnected, when the laptop boots the BIOS hangs for a long time like it was trying to detect the drive, but it doesn't. It turns out that is a system board problem. Hope this helps you on finding the solution. Regards
SOURCE: usb transfer files doesn't work
this cable is design to transfer files from xp to vista or vista to vista.
but you can try by installing the software on both the pcs and tranfer the files hope it will work
