The error code prevents the machine to operate
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
