Question about Fellowes P50CM Shredder
Replacement gear required - Fellowes P50CM Shredder
  • Fellowes Master
  • 1,087 Answers
There is a YouTube video on this.
Dis assembly and Repair of a Fellowes paper shredder - YouTube
www.youtube.com/
My fellowes paper shredder stripped a gear. Here I open it up and fix it with out needing to buy replacement parts.
Posted on Feb 28, 2014
Anonymous
SOURCE:
Can a different gear box fit in a rx4 Renault scenic..if so which.. Reverse gear only..loud knocking.why?
if it is knocking in reverse gear , that is an indication that a tooth of the reverse gear or reverse gear idler is badly chipped or broken
it will require a box strip down and gear and bearing replacement
best stick with the same gear box as there may be too many difficulties to fit a different box
Sep 10, 2016 | Renault SCENIC Cars & Trucks
F250 1993, 4WD will not engage, hubs locked,light comes on? some times a little grinding, workes until I chang gears and goes out.
Ford has fiber gears that have a tendency to grind away and no longer work, requiring replacement.
Feb 01, 2015 | 1993 Ford F250
When stopped gears sometime grind when shifting into 1st gear(2001 Ford Focus)
Then the clutch is not releasing properly & the continual
grinding will wear the gear teeth & you may also have worn
syncros, that will require you to pull the trans & go thru it, as well
as do a clutch replacement
Mar 09, 2014 | 2001 Ford Focus
Empisal sewing machine model 1986 bobbin gear spares
I would suggest taking the machine to a sewing repair shop and having them replace the part.
Jun 16, 2013 | Sewing Machines
How to replace a worm gear on a Bell & Howell model 2585 16mm film projector.
Replacing the worm gear on a Bell & Howell 16mm film projector is a very long and involved process requiring a complete teardown. It is similar to replacing a blown head gasket in an automobile engine. The worm gear is the heart of the mechanism and takes a lot of time consuming labor just to get to it. In the process you lose a bunch of critical adjustments which require resetting with special Bell & Howell tools/jigs/gauges. Many of these projectors are at least 30 to 40 years old and will also require re-lubrication.
The gear itself costs around $30-ish and takes 3 to 8 hours of labor to replace. Richard Patchett in Michigan and International Cinema Equipment in Miami, Florida does the worm gear replacement.
May 04, 2011 | Video Game Consoles & Games
My bike gear is damage to whrer i got the gears
Take it to a Bicycle Shop where they can determine the exact brand and replacement for it. Special tools and knowledge may be required to repair it.
Feb 14, 2011 | Cycling
How do i know if the starter is going out
Most of the time, if the starter is about to give out, you will notice a clicking sound.....make sure that you turn the headlights on to observe if they dim significantly, as this can also be a sign of battery losing charge........if it is slow to start, then this would be a battery fault...........
But, if you hear a click, and the headlights stay bright, then you will definetly require starter motor replacement....if you hear a grinding sound as you start then this could indicate that the gear teeth on your flywheel, or starter gear is also wearing down, replacement required for this as well.......
Nov 23, 2010 | 2000 Dodge Durango
Transit tdci 5 speed box misses 3rd gear when changing down the gear box, changing up generally ok. does not jump out of gear. What might it be? Lee
If its a front wheel drive, they have a lot of trouble with the gearchange cables going out of adjustment or require replacement.
Apr 02, 2010 | 2006 Ford Focus
Where can you purchase repair parts? the teeth are stripped on one of the gears. I need a replacement gear for my Achiever SCS-6 Shredder.
I appreciate your intent to help solve my printer problem. However, I do not think it should require me to pay a fee to get an address to locate a Company to obtain a replacement part for my Achiever shredder.
Oct 02, 2009 | Achiever SCS-6 Strip-Cut Shredder
Fellowes P50CM Shredder Logo
592 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
