The codes we need are known, but how do we put them into an IDIGITAL rm-810 remote control
SOURCE: idigital RM-810 universal remote code to suit Teac SDB440
http://www.chunghop.com/en/products_view.asp?id=302 contact the manufacter
SOURCE: need the code of remote control
It depends on what device name and model you are using it for.
Here is a list of sites that have remote codes:
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
www.hifi-remote.com/ofa/codes.shtml
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
SOURCE: i need the idigital rm-810 universal remote codes for **** smith set top box
Hi, I do not have the codes for it. Most likely you will have to get an original remote for you smith set top box to work it. I do not believe a universal will work with your unit.
