SOURCE: Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
SOURCE: Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
SOURCE: frigidaire freezer CHEST FC263C USER manual. a
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297079200en.pdf
Page 5 explains that the "Red" light is lit until temperature is reached.
