Have checked remote batteries, connections, manual, etc. Equipment comes on, but disc drawer seems to be stuck in a closed position. Is there something I can do to reset/release it?
SOURCE: sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
SOURCE: SL40 DVD drawer won't open.
Unplug the power to DVD player and then replug it back in. Turn power back on and Hit open button on the player.
SOURCE: A dVD disc got stuck inside of the dvd player and
Well it might just be a little glitch with the dvd player to causse this problem so unplud the DVD
player from the wall outlit and let it stay unplugged for about 30 minutes to see if it fixed the problem and there is a small button on the rear of the dvd player that allows the disc's to pop out but you need a small flat head screwdriver to do that. Lastly if zero luck it will need to be repaired then. DOn't take it apart it could make thuings worse.
SOURCE: Cannot open the drawer to insert a DVD
It is possible that the unit got hit by a small voltage surge and if you leave it unplug from the wall for 40Min., it will reset back to normal.
