When I try to play a certain game my laptop crashes with a blue screen error code 0xf4 and ntskrnl.exe seems to be the cause ill have the img herefile:///C:/Users/Owner/AppData/Local/Temp/7zOCA3E54A2/report.htmlalright well thanks please contact me at [email protected] if u find a solution
SOURCE: Problem starting windows
Does the recovery CD give you the option to format your C drive? If not, you can try to get hold of a windows XP disk to do this.
Otherwise you might need to swap your hard drive
SOURCE: laptop crashes
Have you checked the configuration required by the game. Before installing any game, you need to check whether you have configurations that would run that game or not.
It seems that you might not have upgraded video cards. Some games require 3-D card as well.
Check the configurations and let me know.
Thanks.
SOURCE: i cant get a blue-ray disc to play on my hd tv through my laptop
go to "Windows Mobility" select external display and then set display to external only.
ClintM
SOURCE: error appdata
sounds like you have sum spyware malaware or trojan on, google the following programs, kaspersky, xsoftspy, malaware, tune up utilitys 2009 will fix it, if it doesnt re install windows
SOURCE: file ntoskrnl.exe could not be
That file is the kernel, the core file of Windows. Since it's that heavily corrupted the only way to fix it is to reinstall it.
