SOURCE: I need a Fisher and Paykel GW 601 Electric Dryer bearing
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: need steps to change belt on drum of a fisher and
i changed one on a ge unplug electric first or turn off power. I took off my front door 4 screws held the top down look at the top edge where the door closes. this allowed the top to hinge back and you can see the belt and drum . there should be a few screws that hold on the front face lean forward this should separate the front of unit if wires label and remove make sure to put back in same place you can also take picture with camera to really remember you should have some sort of access panel at bottom of dryer remove and look in see if you see the motor with a pulley and the tension device mine pushes up to release tension once all free from pulleys take drum out from front end place belt around drum and stick back in put the belts around the pulleys now replace the front put in screws and spin drum by hand to see if aligned back up an finish up
SOURCE: What is the easiest way to disassemble a Fisher Paykel DE08 Dryer
The video below explains how to take apart a fisher paykel dryer, to do so is pretty simple the dryer repair video should aid you in your appliance repair troubles.
http://www.youtube.com/watch?v=g0Yf2tRE_dA
SOURCE: I want to replace the
Now you need to get your hands on the replacement part for your dryer, you will need to find an authorized F&P servicer to sell you the part (part #479332 btw) or call Fisher & Paykel directly to get the part from them.
OK below at bottom, is a user manual, below, is an exploded parts manual, this should help
www.stokesap.com.au/...DRYERS/517708%20All%20Dryers%2025-03-
www.fisherpaykel.com.au/admin/.../427621B_Dryer_UC_UD.pdf
http://www.hamiltonnorthappliancerepairs.co.nz/parts/dryers.php
Above is a place to get the bearing kit.
