Question about Home Fencing
Having trouble removing old cable from cobra lx1000
I have a none amplified D104 G stand it came off my TRAM D201 IT has a two center leeds that's shielded I know this will work on my cobra 29LTD but I don't get it please help
First, you have to replace the cable as you will need a minimum of 4 wires, 2 of them for the transmit and receive switching, and a shielded cable for the audio. It would be nice to have another as the common for the TX/RX switching but the shield is commonly used for this.
You will need to re-wire the switch in the candlestick to allow switching from RX to TX.
Google "D104 to cobra 29 mic wiring" and you will find many hits for this.
Your microphone was not intended to work with this style of radio. To save a buck, the CB manufacturers removed a 50 cent relay to do the transmit/receive switching. You can see what happens when you remove the microphone when you are listening to the Cobra. It'll stop producing any sound. This won't happen with the Tram,
Also, you may have problems with the microphone as it is high impedance as indicated by no transformer or preamp in the base of the microphone. This may be a problem as the Cobra has a relatively low impedance input.
Aug 07, 2016 | Cobra Radio Communications
I'm having trouble removing the old battery which is dead. Any help?
There is a small nut on the side of the battery at the bottom 13mm I think. Remove battery cables and lift out If you can't get the cables off and they use bolts use vice grips or cut it off and buy a new one at the hardware store. Make sure there are sparks near top of battery. Put on safety glasses
Dec 04, 2011 | 2003 Dodge Caravan
Philips LX1000 not booting up
I need many more information
1) is their a power on the CPU. if yes lets check the monitor, uplug the monitor and turn only the monitor on, their should be some message on the monitor. If no error message on the monitor, possible monitor issue.
2) do you find any error message on the screen
2) If no light on the tower, do you find any light on the back.. please reply to this question
Dec 15, 2009 | Computers & Internet
Old dynamike plus wiring for a super star 3900
1-Shield
2-White
3-Red
4-Black
Check the mike plug to make sure that none of the wires have broke off.I would also check the mike cable with an ohm meter.
Jan 02, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 29 ltd sound tracker cb
you start by replacing every electr cap as most cb radios live in a hostile enviorment, They ALL suffer from dried up electolite. if the set is old ,that will be you first step,if you are up to speed with desoldering with out lifting copper tracks/etc, no reason why you can't have a go...do not shift trim pots or tuning can slugs
with out marking their factory positions as this can end up in a
mess
CHEERS
Jun 26, 2008 | Cobra 29 LTD CB Radio
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at [email protected]. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
Feb 13, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Adding addresses
Have you tried resetting unit to the factory default? To get to this, press the snake button, then settings, then user settings. On the last page you will see reset to factory defaults. This will erase all info on the device as if it were new.
Jan 12, 2008 | Cobra NavOne 4500 GPS Receiver
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Home Fencing Logo
242 people viewed this question
Top Home Fencing Experts
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
