Televison & Video Logo
Posted on Oct 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pictures colors do not line up
Its like three picture that don't line up and the picture is blurred like double vision.
Anonymous
Level 3:
  • Master 934 Answers
  • Posted on Nov 30, 2007
Anonymous
Master
Level 3:
Answers
934
Questions
Helped
504499
Points
2229
The convergence amp(s) need to be replaced. Your unit takes two STK392-110 Sanyo built amps. In addition all the low ohm resistors should be tested for change in value and replaced as needed... Not an expensive repair for a qualified shop. We do four or five a week...
Bill
1helpful
Red color, lines doubled . doubled vision. blurred vision
replace the convergence ICs and check the low ohm resistors also.
5helpful
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
2answers
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
TV is blurred or double vision
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Double vision
If you are printing color and you have color blurring like streaks. it mean the registration of the colors are off. Usually using the internal cleaning function from the panel will clear this up. You should restart the copier as well. If it continues check all the feed rollers.
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
6helpful
Blurred/double vision Samsung HDTV 1080i projection
Your convergence ICs are bad and maybe the two resistors right next to them. This is an easy and inexpensive repair if you can solder. A repair shop will run about 400.00 The parts are readily available for about 10.00 each you will need two ICs STKXXX-XXX
Look inside your set for a large aluminum heat sink that's where hey are located they will have an STK number like above stamped on them. Those are the part numbers. Let me know what type of TV and model number you have and I can help you locate the proper parts.
2answers
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
