Question about Nikon COOLPIX L4 Digital Camera
How to connect camera l25 nikon coolpix for web cam
6ya staff
SOURCE:
Anonymous
  • 2985 Answers
SOURCE: Driver Installed
Diditial camera do not need 'drivers' for PC's operating with WinME/2000/XP/Vista
Windows does it all
Posted on Jun 01, 2008
Anonymous
SOURCE: nikon coolpix L12 software
Throw it in the bin!
Posted on Jul 15, 2008
fblock
Fred Block
  • 289 Answers
SOURCE: my nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Posted on Apr 29, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jun 28, 2009
Ty Price
  • 11967 Answers
SOURCE: Nikon COOLPIX ISO 2000,10 megapixles CAMERA is
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 15, 2009
Testimonial: "nikon camera lens is error what problem i can't understand. pls tell me regards Saiman"
HOW TO CONNECT MY NIKON COOLPIX L820 AS WEB CAMERA IN MY COMPUTER
You are all idiots, He asked how to use it as a webcam, not how to read the pictures on it.
Sep 29, 2013 | Nikon COOLPIX L5 Digital Camera
How can i use nikon coolpix 5000 as a web cam
The web cam is designed for constant live imaging where the digital camera handles a series of shots and short movie durations, not suitable for this type of perpose.
Jun 09, 2012 | Nikon COOLPIX P5000 Digital Camera
I am having a nikon coolpix digital camera But it does not work as web cam. Can someone tell how it works as Web cam
The 5700 is designed to store images (and videos) to memory, not to stream live video to another device. It cannot be used as a webcam.
I know this wasn't the answer you wanted to see, but there it is.
Aug 15, 2010 | Nikon Coolpix 5700 Digital Camera
How to adopt my nikon s220 as web camera ?
Answer ID 491 Can I use my Nikon Camera as a "Web Cam" Can I use my Nikon Camera as a "Web Cam" --> No, the camera does not have this type of digital video output. You can not use the camera as a "Web Cam."
Jul 24, 2010 | Nikon Coolpix 2200 Digital Camera
I have nikon coolpix camera. can i used it as web-cam for video chat? if yes then what will be the procedure? please guide me
Hi there you can not use it as web camera.BUt if you buy a videocard then you can. But its costly than a webcam. You will get 3 - 4 webcam on same cost of video converter card. I suggest you buy an iBall webcam its good & also a pixel cam. Nice clearity & with microphone. You can take a snap from than webcam also. It will cost arround 12$ - 15$. Thanks.
Mar 20, 2010 | Nikon COOLPIX L10 Digital Camera
Can i convert nikon coolpix L4 into a web cam
this camera dose not have facility use like web camera u can use USB connectivity allows quick easy data transfer to computers and other peripherals
Nov 15, 2009 | Nikon COOLPIX L4 Digital Camera
Coolpix as a webcam?
No. The camera records, does not stream.
Aug 12, 2009 | Nikon COOLPIX L12 Digital Camera
Nikon 3200 as a web cam
You can't use it as a webcam.
Have you retried the update?
Nov 01, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
304 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
