I've followed the instruction to setup a new harddrive on my Windows 7 Dekstop, yet when I click on Start.exe, an error occur stated that the version of this file is not compatible with windows running. need an (32 bit)or(64 bit) version of program, then contact the software publisher. While when I click on Lacie Setup,it stated windows cannot find'E:contentsLaCieSetup.exe.'What should I do? Could you please assist me on this? I've tried to dwnload the driver from here as well yet same thing happens. Thank you so much and do really appreciate your assistance
SOURCE: I need to download the
Please click on the below link or copy the URL and paste it in your web browser. And follow the steps. To download the drivers click on the Download which is present in the right side of the document.
http://www.lacie.com/support/faq/faq.htm?faqid=10550
OR
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Lacie-USB-2-Driver.shtml
OR
http://list.driverguide.com/list/company1220/
Thank you.......
Posted on Sep 24, 2008
SOURCE: while installing MTK driver for
MTK driver for LG GX200 is not installig on Windos7.Needs remedy.
Posted on Aug 13, 2011
is the scratchy sound coming from inside your lacie or outside ??
it might be a power problem trying to connect to your lacie but unable to find the device or a dirty hard drive the reader arm skipping across the platters you could give your lacie a firm tap on the side to free up the reader arm
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
3. the following screen a window with your username appears.
Type your windows password as you would log on to your account and press "OK":
4. The next screen offers several options to repair or diagnose your computer system.
To start the recovery, click on "Toshiba HDD Recovery":
Step 2 - Performing the HDD recovery
1. After passing the previous screen, you will be asked if a backup of your important data is already made.
You can continue with the recovery process by clicking on "Next"
2. Confirm the following screen also by clicking on "Next"
3. You will be asked again if you want to recover your machine (and delete all files on your harddrive).
There are no additional options regarding the harddrive, which can be set. Click on "Yes" to start the recovery.
4. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
5. By pressing the "Restart" button to restart the machine, the recovery procedure is almost finished
Step 3 - Finishing the recovery process
1. After the successful completion of the recovery process and the restart of your machine, the following screen should appear.
2. The installation wizard of Windows Vista / Windows 7 will start
up to guide you trough the setup for your newly installed system and to
finish the installation of the operating system
FOR WIN 7 Toshiba System Restore Windows 7
How to recover a Toshiba with the HDD recovery procedure
- Operating System: Windows 7 - 32 Bit, Windows 7 - 64 Bit, Windows Vista 32 Bit, Windows Vista 64
Bit
The following guide describes how to recover a Toshiba with a preinstalled Windows windows 7 from HDD through the
"HDD recovery procedure".
Please note:
First of all, make sure you already back up your important data!
Step 1 - "Initiating the HDD recovery procedure"
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.Choose the
entry "Repair your Computer" and press "Enter":
1. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and
click on "Next".
If unsure, just click on "Next".
1. In the following screen a window with your username appears.
1. The next screen offers several options to repair or diagnose your computer system.To start the recovery, click on
1. After passing the previous screen, you will be asked if a backup of your important data is already made.You can
1. Confirm the following screen also by clicking on "Next"
1. You will be asked again if you want to recover your machine (and delete all files on your harddrive).There are no
1. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
appear.
1. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly
installed system and to finish the installation of the operating system
Hope this helps,
Hope this helps,
