Radio Communications Logo
Ron Howell Posted on Jan 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cobra 19 classic
It lights up but does not tx or rx
  • Mike Charette Jun 05, 2014
    Hi Ron Howell, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
James Walker
Level 2:
Habit-Forming:
New Friend:
  • Expert 65 Answers
  • Posted on Mar 05, 2015
James Walker
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
65
Questions
0
Helped
27505
Points
126
Try changing your mic.
Clint Millett
Level 2:
Novelist:
  • Expert 217 Answers
Clint Millett
Expert
Level 2:
Novelist:
Answers
217
Questions
0
Helped
87114
Points
355
I would open up the radio and look for burnt traces, primarily by the output transistor and near where the power comes in. If you have another radio near by (within several feet) and it transmits on the same channel that your radio is on, can you hear it?? If you transmit on your radio, does the working one hear you? If you open your squelch, does it make noise?? If you transmit, does the RF power meter go up?? If any of these questions are YES, then there is a good possibility that your ANTENNA SWITCHING diodes are shorted or open. The TX diode is probably open and your RX diode is shorted. OR both. If the other radio is hearing you, and you are hearing the other radio, then the radio section is very likely OK. The diodes switching the antenna between RX and TX often fail, especially if there has been a lightning strike in the vicinity. It doesn't matter if your radio is on or not, or if you have a surge protector, a nearby lighting strike can take these diodes out.
If you don't have as much as a Channel number coming up on your radio, then the problem is most lkely somewhere in the radios internal power supply.
5 Related Answers
Tumbleweed01
  • Posted on Mar 16, 2008
SOURCE: 29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Anonymous
  • Posted on Feb 14, 2009
SOURCE: i have a Cobra 29
Have you tried using a different mic that you know is working properly? If it still has feedback, then someone has installed talkback. Take the top off, check for a resistor between external speaker and pa speaker ports. Remove resistor if it is there and that should remove the talkback. Hope this was helpful.
Anonymous
  • 463 Answers
  • Posted on Mar 20, 2009
SOURCE: codra 29 nw ltd classic
Hook radio to antenna. Key radio. Pester nearest trucker for radio check on ch 19. Can trucker hear you OK? Can you hear trucker OK? then meter is bad or connection to meter bad.
Can you hear truckers, but they can't hear you? Final Output transistor is bad...
Anonymous
  • 6966 Answers
  • Posted on Oct 30, 2009
SOURCE: MY COBRA 29 LTD CLASSIC WILL NOT TX BUT RX VERY
Hi and welcome to FixYa,
Initially, check the final and driver, TR14 and TR15 using a transistor tester or ohmmeter..
Postback results.
Good luck and thank you for asking FixYa.
Anonymous
  • 1274 Answers
  • Posted on Mar 12, 2010
SOURCE: Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Testimonial: "Thx the rx/tx light is supposed to turn red I found out. Still trying to get the antenna prob fixed though."
1helpful
2answers
Wiring the mic 4 pin
LINK WITH DIAGRAM....
http://www.wearecb.com/cb-microphone-wiring.html
1helpful
148 gtl cobra cb radio and the rx/tx light stay on
This sounds like a problem with the MB3756 Regulator IC. It controls voltage regulation and TX/RX Switching. It is a common failure in these radios. Check voltages with schematic that can be found at
CB Tricks Home Page
2answers
Cobra 29 ltd Classic no sound, no rx, all lights work rx,tx, lite up. The SWR meter moves when mic is keyed up.
Check speaker and plug external one in if you have it.
swap mic could be a broke wire or bad switch in handset.
check antenna and coax connections.
i know checks sound basic but they could save you a lot of headaches later
1helpful
MY COBRA 29 LTD CLASSIC WILL NOT TX BUT RX VERY WELL. CAN'T SEEM TO CALIBRATE CORRECTLY.
Postback results.
I have a deisel 4-7 echo mic ineedcolor to pin to wire it to a Cobra 29 ltd classic thank you so much
cobra:black--ground
yellow--mic
red--tx
blue--rx
the wiring for the echo mic is identical
Radio lights up, but no TX/RX.
Based on your description, a possible drift in the local oscillator.  Check the 10.24Mhz crystal filter and its local oscillator for output and consistency.
2answers
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
1helpful
Cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
