I have two remotes for my "Viper 1-way remote start model: 5101" One stopped working and the other only worked 50% of the time. Swapped out the batteries (CR 2032)in both and now neither remote works. I had this installed in my 2006 Ford Five Hundred in October 2009 at a Best Buy. Any help would be appreciated. Thank you.
Ignition switch maybe .
I know it sounds simple, but are you sure you put the batteries in correctly? They are easy to put in wrong and you also can't rule out the batteries you have are old and/or defective. Also, by not working, do you mean the FOB's work (usually an indicator light) and the remote starter doesn't respond or do you mean the FOB's don't light up?
Testimonial: "Both FOBs light up, but the commands are not happening (car starting, unlocking doors)"
SOURCE: RCA Universal Remote stopped working
I also have the same problem with my rcv remote and it started when the batteries accidently feel out
SOURCE: Pregramming my RCA Gemstar Video Plus remote with no codesearch button!
www.remotecodelist.com ........................................T.
SOURCE: Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
