Question about Whirlpool GS6SHAXLS Side by Side Refrigerator
Whirlpool refrigerator not cooling. Ice buildup on coils and refrigerator temperature panel blinks every 10-20 seconds
Hello Experts, Thank you for taking the time to help me with my problem. My Whirlpool Gold side by side # GC5SHEXNS00 refrigerator is not cooling properly. The fresh food side is not cooling and the bottom freezer section was colder than the top. There was ice build up on the coils in the freezer section, the fan on top of the coils was running, and the temperature control panel blinked every 10 seconds with a chirping sound. The electronic damper door from the freezer to the refrigerator closes shut if I manually open it thus not allowing any cold air into the fresh food side. A repairman was out and said I needed a new control board located at the bottom rear of the refrigerator and that I could order one and replace it myself. I have since melted the ice on the coils and replaced the main controller board but the damper door, panel blinking, and high temps in the fresh food side is still there. Can the temperature control panel be bad (blinking)?
1 Related Answer
ckwizombe
Collins Kwizombe
SOURCE: Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
Fridge running continuously (compressor not stopping)
Both Freezer and fresh food component runs perfect temprature.
Posted on Nov 21, 2013
Whirpool Gold side by side GC5SHEXNS00 fresh food side not cold. Evaporator fan only getting 10 volts should be 12Vdc. Replaced Inverter box and fan motor what's next?
Boris, we are sorry to hear that your Refrigerator is not cooling. We are not technicians, we do not have technical training, or technicians here in customer service. We can offer troubleshooting. Unfortunately, we do not have the provisions to assist you with detailed technical advice, provide repair manuals, tell you how to take it apart, or advise on which parts need to be changed to repair the unit. We do not offer repair assistance in customer service. If you are unable to resolve an issue on your own, we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected]
Jun 08, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
The water dispenser and the ice maker have stopped working on my Whirlpool Gold GS5SHA. I have cleaned and defrosted the ice maker. The lines look clear. Any suggestions? Thank you.
Hello Kent, with the work you were doing on your frig did you shut off the water valve and just forget to turn it back on. This is a very common problem. Check and see, GOOD LUCK.
Oct 11, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Refridgerator side stop working on whirlpool gold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whirlpool GC5SHEXNS00 side-by-side refrigerator that has stopped cooling. For quite some time the center column was hot to the touch, but it maintained the ability to cool. Now it no longer cools...
If the center wall was hot then your defrost heater was stuck on, now with no cooling it could be you burnt out the compressor or the main board could be fried. Not good either way, it might be time for a new one. Sorry
Nov 09, 2010 | Whirlpool GC5SHEXN Side by Side...
Whirlpool Gold Model GS5SHA Side by side. Freezer working, refrigerator side not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
My whirlpool gold side by side serial # slo539783 model #gd
Sound like you have a refrigerant leak I suggest to take it to a pro because you need lots of tools and knowledge to properly fix it And don?t let people tell you than is just to add refrigerant because that is a common myth or miss conception, refrigerant don?t ware out or burn out if the system need refrigerant is because there is a leak some where.
Jun 07, 2009 | Whirlpool Refrigerators
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
May 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL REFRIGERATOR
my refrigerator gold is running but not cooling I have the model number and serial numbers if that is helpful please help
Apr 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6SHAXLS Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
