Question about MA Audio Car Audio & Video
Have you installed Kicker capacitors? With the extra power you have you will need them to help with the load.
Posted on Jan 28, 2014
SOURCE: MA Audio MA 1200XL Car Subwoofer
that subwoofer has dual 4ohm voice coils, if your amp can handle 2 ohms, you would put a wire from the positive (+) on the amp to the positive on both connectors on the sub, then hook the negative (-) on the amp to the negative on both the sub connectors that will be a 2 ohm load on your amp make sure your amp at 2 ohms is not more than 600 watts RMS or 1200 max.
Posted on Jan 08, 2009
SOURCE: ma120xe sound horrible
Make sure that you have the subs wired in a 4-ohm series and not a 8-ohm load
Posted on Dec 23, 2007
SOURCE: What Kind Of Car Amplifier Do I Need?
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Posted on Jul 24, 2009
