Question about Jet Tech Systems Dishwashers
No heat from F-14 - Jet Tech Systems Dishwashers
Robert Marsolais
    Problem Solver:
  • 25 Answers
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
Posted on Jul 15, 2014
Im replacing the electrical cord on a 1500 watt 12.5 amp 120VAC,60Hz heater.Is 14 guage sufficiant?
14 gauge will be enough provided your breaker is a 15 amp. If 20 amp I recommend 12 gauge wire.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Heating & Cooling
240 volt thermostata
Aube Technologies should be able to supply wiring information.
Jan 28, 2014 | Aube Technologies TH115-A-240S - Aube...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Fuser temp
If you need to reset a heat fault. Press # * C * and the machine will enter diagnostic mode. Enter the number 14 , like you were making 14 copies. Press 1 and then start, Some machines will reset just pressing 14 and then start. But 14 is the number used to clear fuser heat faults
Jul 28, 2010 | Sharp Office Equipment & Supplies
I have a Rudd Achiever 14 and I want to know if
Take the front panel off the air handler and look for a heat element. You should notice controls and relays with larger wiring to it. It may not have any heat but you can add it.
Jan 05, 2010 | Ruud Handler Air Conditioner
No heat bought heater treater what does code 14 mean?
1st, what is 'heater treater?' Is this something you add to the cooling system? Is your engine temp gauge in the normal range, or is the jeep running at the cold end of the temp. gauge? Is the fan for the heat/and a/c working? There are several reasons you may not have heat.
1.make sure coolant level is ok, low level will cause a no heat condition.2. If engine is not warming up properly (running at the cold side of temp gauge), you may have a thermostat that's stuck open, not allowing the engine to reach operating temp-result, no heat.3. If you can hear the fan blowing for the heat-a/c, but not feel it blowing at the vents, your 'blender door' (opens and closes to allow heat-a/c to enter the cabin) may be stuck closed. I had a Jeep (4L engine, but older than yours) which had a valve in the heater hose line that once froze up (stuck closed) and resulted in a no heat situation. If the heater treater is something you add to the radiator, I wouldn't waste the $ to use it, as it probably won't help this problem. Your codes: I could find no code 54, #14 is 'B' camshaft position sensor -timing over advanced, or system performance bank 1.
Nov 17, 2009 | 2001 Jeep Grand Cherokee
No heat
Check the resistance of the heating element (8 to 14 ohms). If ok, then check continuity of the overload devices attached to the heat element duct. If either one or both are open then replace ($14 for both). Dryer should heat.
If heat element is faulty, the part can be purchased at Sears/Kenmore Parts Center and swapped out ($45.00).
Provide your dryer model number and ask for the needed parts.
Unplug your dryer first before attempting any service work. Safety first and always!
Dec 19, 2008 | Whirlpool LER4634J Electric Dryer
Dishwashers Logo
65 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Colin Stickland
Colin Stickland
ray gallant
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
