Question about Staples SPL-P500 Printing Calculator
How to set the tax+ and the tax- - Staples SPL-P500 Printing Calculator
How do i set the tax rate for Casio QT-6600?
go to PGM 3 then go to
1- Machine Feature
go to
9-Tax Table
go to
1- tax table 1
set tax rate to 5.0000
set Rounding to Round up
set singapore Rounding to Round up if you are not using the 1 cent anymore
set calculation Type to Table and Add on
Press ESC to go back to Tax Table window and choose
2- Tax Table 2
repeat the same steps as for Tax Table 1 but set the tax rate to 9.98
Jan 31, 2013 | Casio QT-6600 Cash Register Touchscreen...
I have set the tax amount, but can't change the departments for tax an dnon tax
In the department programming section, there should be a setting to turn on each tax (tax1, tax2 etc). Turn on or off the tax that you just set the rate for.
Feb 17, 2012 | Casio Parts Cash Register PC Desktop
Casio hr-100-tm I have set my tax rate at 0.825 now when I add 100+ tax it gives me 100.83 instead of 108.30 how do I fix this
There's nothing wrong. If you have a tax rate of 0.825% then the tax on 100 is .83. If you want 8.30 tax on 100, then set the tax rate to 8.3%.
Nov 12, 2011 | Office Equipment & Supplies
How to change the currency and tax rate values on
Press the red "ON" button and hold it. Press and hold the "% (SET)" button and hold it. Release the red "ON" button. Continue to hold the "% (SET)" After a few seconds, "SET" will appear at the top of the screen. Press the "TAX (TAX RATE)" button. "M TAX SET %" will appear at the top of the screen. Your current tax rate will now be shown in the display. Enter new tax rate and press the "% (SET)" button. Your new tax rate is now set.
Jan 16, 2010 | Casio Office Equipment & Supplies
Manual for Casio MS-120TE Calculator or how to program exchange rates
press AC
press RATE SET, hold for approx5 secs till you see "tax" "%" displayed
type in new rate (say 20)
press RATE SET (to confirm 20% as new tax rate)
Done
Oct 19, 2009 | Casio Office Equipment & Supplies
How do I set the tax rate on LS-80TS?
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
Oct 06, 2009 | Canon LS-100TS Calculator
Casio fr-2650 plus calculator
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Apr 05, 2009 | Casio FR-2650Plus Calculator
Change the tax rate on calculator on MS-8TV
cliff notes:
hold set% button
hit tax+ button
hit set done
Mar 23, 2009 | Casio Office Equipment & Supplies
Tax Key
So just 5 easy steps to change the rate
1 press the AC button
2 hold down the SET /SET % / button for a few seconds
3 press the TAX + button
4 input the rate /in your case 6/
5 press SET button again
And you are done. You can also check it - press the Tax + button and the current tax rate will appear
Hope I helped !
Jan 05, 2008 | Casio MS-80TE Calculator
How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact [email protected] - he emailed the solution to me and it has worked.
Pam
Oct 10, 2007 | Casio HR-100TMPlus Calculator
Staples SPL-P500 Printing Calculator Logo
159 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
