Question about HP Computers & Internet
Lcd philips 42pfl9632d 10
I try to connect my HP pavilion laptop to the philips TV using the HDMI output and got the message "no signal". other sources via the same HDMI input works well !!
Posted by Itzhak Fuchs on
Mick Ard
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
You may have to turn on HDMI on your laptop or load drivers?
Posted on Jan 28, 2014
Testimonial: "please, How do I turn on the HDMI in my HP pavilion, Itzhak"
  • Mick Ard
    Mick Ard Feb 09, 2014
    Check that HDMI is on in the bios.
5 Related Answers
Anonymous
  • 34 Answers
SOURCE: HDMI Sound
YOU MUST MAKE A DIFFERENT CONNECTION OF YOUR PC SPEAKER TO YOUR TV , YOUR SOCKET IS FOR VIDEO ONLY
Posted on Oct 27, 2008
Jidza
Jidza
  • 24 Answers
SOURCE: Unsupported Signal. Adjust your PC output
Boot into safe mode or VGA mode and reduce the resolution to 800 by 600 and set the refresh rate to 60. After this, reboot normally and check the box to have your video to display only the settings that work for your system, and choose the desired resolution, and refresh should be 70-85 to reduce flicker. Appears as tho your video card is set too hot for the monitor.
MORE: In safe mode or vga mode you may not be able to adjust the settings. Fine. After a reboot, you may be able to start normally and the vga settings might still be there (640x480). Then you can adjust them.
Posted on Jan 23, 2009
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: Motherboard GA-MA790FX-DQ6 no monitor
your power supply is too weak to power your video card.
Posted on Mar 11, 2009
Anonymous
  • 27 Answers
SOURCE: Unsupported Signal. Adjust your PC output.
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
Posted on Aug 29, 2009
Harleen Nash
  • 1768 Answers
SOURCE: Trying to connect my pc to tv have a message on
Your TV you are trying to connect to the pc may not be compatible with the connecting device or the connection output to the TV is incorrect.
Please provide more information as to you issue such as :
a. model number
b. year manufactured
c. Has the manual to the TV been viewed
d. PC information needed (out puts/inputs)
Posted on Jul 03, 2010
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Hooked up my HP pavilion dv7-1240us (Vista) to our HDMI cable, then into the TV, as usual. Slept he computer, then disconnected the HDMI cable. Since then, I cannot get any screen at all. Have tried...
restart pc in safe mode, change video back to standard VGA of HD VGA video. PC has to be in HDMI mode and your TV has to be PC mode. Use a DIV to HDMI connector or better yet HDMI to VideoPort if your TV supports it, HDMI almost never gives you the screen output you really want anyway.
Jan 17, 2014 | HP Pavilion dv7-1240us Notebook
Connected laptop to tv, but sound only come from laptop. How can I make the sound come out from tv?
If your laptop has a HDMI output, and your TV has a HDMI input, then use a HDMI-to-HDMI cable, which carries both "audio" and "video" signals.
Otherwise, you need a cable from the "headphone" output from your PC into the "RCA" stereo-audio inputs into your TV.
Dec 20, 2010 | HP Pavilion dv6-1030us Notebook
When I connect my Laptop to a Philips lcd tv via HDMI cable, the video is ok but the sound is missing.
Hey FixYa
Thank you for your answer.
My problem is that my graphic board in my HP Pavilion Laptop dos not support sound from the HDMI output, only video. That was the reason
why i could not hear anything from my Philips lcd TV.
I wish you all a happy New Year.
Greetings from sgkbcl
Dec 27, 2009 | Philips 52 In. LCD HDTV
Big screen for laptop
you did not mention the model of your tv. usually lcd tv's only support some resolutions.
right click on your desktop choose properties then settings you can change you screen resolution there windows will change back in 15 seconds to the old resolution. try the different resolutions availbe to you.
Apr 24, 2009 | HP Pavilion dv1000 Notebook
Connecting asus notebook via hdmi to LG 42 plasma tv
best option to use s-video lead ...use fn + f-key that has little square printed on it ...hp mostly fn+f4
Jan 11, 2009 | HP Pavilion dv6000z Notebook
Problem hdmi connection
Hello, I'm from the Netherlands and I had the exact same problem with my philips lcd...
So what I did, was upgrading the software of my videocard (nvidia.com),this resolved my problem of giving a error on my laptop and restarting.
Then I got the message on my tv: "video not supported' , this I don't know exactly how i resolved this, but i tried fn+f4 a couple times. If that doesn't work you have to do something with the nvidia control panel (right click on desktop).
So now i had picture, but no sound.
To enable sound from your laptop to your tv you have to go to control panel>sound> set the SPDIF to your standard sounddevice and tick the box with wma audio something, tick out the other boxes.
I hope this will resolve some of your problems and others who have the same problem.
greetings,
Sam
Dec 14, 2008 | HP Pavilion dv6000z Notebook
Signal loss from GF9600GT to LCD 42PFL9632D
the issue may be hdcp, if both the pc and tv arent enabled you wont get a picture.
try to connect dvi to dvi or if you havent got dvi try an adaptr
Mar 19, 2008 | Televison & Video
HDMI-No signal input
Turning the power off shouldn't have caused the problem.
Make sure the TV is set to the correct HDMI (1 or 2) by pressing AV on the remote and moving up and down the list.
Check the laptop is set to output through the HDMI socket.
Right click on the desktop -----> properties ----> settings
Actual options depend on your graphics card.
Jan 02, 2008 | Philips 42PFL5332D 42 in. LCD Television
Computers & Internet Logo
67 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
