Question about Paradigm PS 1200 Speaker
Paradigm Pw 2100 Speaker
Power amp repair
ric V
    New Friend:
The amplicator is stop after 5 second play
Posted on Sep 19, 2016
What is the impedance of the 12" driver in this subwoofer
PS-1200 Specifications
Design
Single driver, DCBS™ system with high velocity resistive ports and built-in amplifier Amplifier High current, hybrid output, 130 watts RMS
Amplifier Features Powersaver auto-on/off, soft clipping, thermal protection Low Pass Filter Frequency Variable 50Hz-150Hz Low Frequency Driver 310 mm, carbon-fiber-reinforced composite cone, Apical™ former Low Frequency Extension 23 Hz (DIN) Sub / Sat Phase Alignment 0 - 180 Finishes Black Ash Inputs From A/V receiver/processor or Paradigm X-Series Control Unit or preamp left/right output; From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 68 lbs. (31 kg) Dimensions HxWxD 19.75" × 17" × 21"
(50cm × 43cm × 53cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
What would cause paradigm sub12 not to power on
The inside of a subwoofer isn't really a great place to put an amplifier, that that is what you have. These things do go bad from time to time.
You may be able to get it repaired, or you could replace the amp. You're looking for a "plate amp". Parts Express has a good selection:
Subwoofer Plate Amplifiers
I have a pair of Paradigm Monitor 3 V.2 High Def speakers for my front L&R home theater system. On speaker sounds very tinny with no bottom end. On inspection neither the main or tweeter loo
A few questions to help me help you: (1) Does the woofer cone move freely when you use your hands to move it (or do you feel friction)? (2) have you tried swapping the left speaker for the right to rule out the receiver as a cause?
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
My paradigm ps1000 speaker does not turn on what's wrong ?
Check all fuses and plugs, if they are OK your power supply may have failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Ps-1200-A sub woofer will not power up
Probably a blown fuse. If there's not one on the face of the amp, pull the amp and check for one next to the power cable.
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Paradigm monitor 9 v.5
The more power the better as far as amplifiers go, underpowering speakers causes clipping and burns up voice coils. Having a high power reserve means you have higher headroom for transients, with more power the amp will be able to handle transients better and will not be running at full output all the time in order to get desired volume levels, hence more headroom.
If you want to go with quality go with components, a seperate dedicated high quality amplifier such as a haffler, crest, etc., amps you find powering monitors in studios. It all depends what you want.
Lightning struck and my paradigm ps1000 doesn't work anymore.
Paradigm service is excellent and they can supply parts. The amplifier has a one year warr. Check with a dealer or www.paradigm.com Your insurance may cover it.
Paradigm PS 1200 Speaker Logo
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
