Question about Quad Cycling
Runs but not idling
My MCI Alien 2010 model scooter has 7000ks on the clock. It starts and runs, but just dies if i stop at traffic lights etc. If i give it gas it will not die, I think i need to adjust the idle screw, but cannot locate a manual for this scooter, does anyone have a picture or manual to help me locate this screw? Otherwise it will be a trip to the bike shop.
Posted by Carley Cole on
Mick Ard
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
The idle screw is normally found on the carburetor and is a screw with a spring, close to where the throttle cable enters the carb.
Posted on Jan 28, 2014
5 Related Answers
lonewolf1996
Lincoln Brunell
  • 142 Answers
SOURCE: it starts fine an idles pretty good and smooth but
It sounds like a carburetor problem.You need to make sure the diaframs in the carburetor are good.The last thing you need to do is set the high and low speed needles.If its the same as mine,it will be on top of the carburetor.
Drop me a message if you need more help.
Posted on Jul 27, 2009
Adrian762
Adrian Ahrens
  • 425 Answers
SOURCE: i have an mci alien 50cc scooter the oil light
Three things will cause this:
1: The sensor is cactus
2: The sensor is blocked (with gunk) and can not function.
3: There is no oil pressure to make it function.
2 is easy, you just take it out and clean it, if the problem is rectified then all is well. If not, you replace it, if the problem is rectified then all is well. If not you take it to a reputable bike mechanic, or get a manual and get it fixed. But I did not think that small bikes used oil pumps, I was of the opinion they used the oil spash technique. Could be wrong??????
Posted on Feb 06, 2010
Anonymous
SOURCE: oil light
the oil sender [switch] is plugged into the oil tank check the wires are still plugged into wireing lume if so the switch will more than likely to be at fualt
Posted on Feb 16, 2010
Blake Pounds
  • 201 Answers
SOURCE: my pocket bike stops running, and revs by itself
It could be a clog somewhere or he fuel pump. Hope this helps!?
Please rate solution - Thanks.
Posted on Apr 20, 2010
Eduardo Rodriguez
  • 25 Answers
SOURCE: I have a chinese scooter starts and idles for a
check the hoses that put gas on the carburator, and also the pump. Check the spark plug, better take it off and clean it and check the gap.
Posted on May 19, 2010
Why is my car messing up
Obviously its problem with your fuel to air mixture. It is building up unburnt fuel due to not enough oxygen. This lack of enough oxygen will cause the stalls and the build up of gas will cause the backfires. Heat affects the mixture ratio. A number of detector are involved in the exhaust system and any one of them could be failing. Throttle Position Sensors, MAP sensor, Oxygen sensors, catalytic converter, etc. You should be getting the check engine light coming on also. Any auto parts place can read you the code numbers for free. They will provide more specific information about failing parts.
Aug 13, 2014 | 2010 Nissan Maxima
Engine runs bad, sometimes dies when put into drive or reverse
CHECK FOR OIL LEAK ONTO SPARK PLUGS REPAIR AS NECCESSARY
Aug 19, 2012 | 1993 Saturn SL2
50cc scooter lack of power from 0 to 10mph
Fuel mixture is too rich. The easiest way I adjust those is to have a friend stand in front of the scooter, holding the wheel and handlebars still while I lightly hit the throttle and at the same time, adjusting the fuel mixture screw on the carburetor slightly. applying the throttle harder while adjusting, you should feel the scooter gain or lose power.
Mar 01, 2010 | Beta Alp 4T 200 Motorcycles
I have an mci alien 50cc scooter the oil light remains on even though the oil is full
Feb 05, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Oil light
2000 Alero idles low and dies when stopped.
How does it idle when you first start or idle when hot.
On the top of the air intake tube there is a small screw which should when screwed in speed up the idle and if it dosent work or it idles fine when cold or warm at idle then its your GEARs are binding up and there's not to much you can do about that ........sorry
Oct 15, 2009 | 2000 Oldsmobile Alero
RUNS ROUGH & STRONG SMELL OF PETROL WHEN STOPPED AT TRAFFIC LIGHTS FEELS LIKE IT WANTS TO STOP. WHEN I TAKE IT OUT OF GEAR & GIVE IT SOME ACCELERATORE IT RUNS OKAY.
first of all you have to check serivce status of car .. like air filter .. etc
do a diagnostic check
it might be something in your air intake system .. sensors .. idle
Jun 28, 2009 | 1996 BMW 318
Idles fine then dies when put in drive or reverse
You may have a problem with idle speed control motor or ETC as GM calles it. here is a photo and a price from rockauto.com.
Motor Assembly sa4_full.jpg $110.99
Apr 18, 2009 | 1990 Cadillac Fleetwood
Cycling Logo
104 people viewed this question
Top Quad Cycling Experts
Marvin
Marvin
NOEL
NOEL
Kardoc
Are you a Quad Cycling Expert? Answer questions, earn points and help others
