1997 Volkswagen Jetta Logo
Posted on Jun 03, 2009
97 jetta linkage messed up
I just bought a 97 jetta for this guy and the only thing is wrong is the linkage. the linkage feels like it is spring loaded to the passanger side of the car and cant get all the gears. the reasion for this is cuz the guys son took the shifter linkage apart and i think he put it together wrong. if u know how i would be able to fix this please let me know. email me at [email protected]. thank you
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
3779
Points
15
Check a good VW service manual, there is a special alignment gauge for the shifer assembly that is required to set up the shifter if it is dissasembled.
the tool is very reasonably priced, and can be found at several companies that sell specilized auto repair tools.
My guess the last owner probalby got a "short shift kit" and shifter rebuild kit from one
of the places that sell VW performance parts & messed up the installation. these kits work very well , if you put them in right!
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Jun 03, 2009
Anonymous
Contributor
Level 1:
Answers
41
Questions
Helped
17149
Points
98
Its probaly just an adjustment on the linkage
1997 Jetta Passenger Door is stuck closed
sounds like the linkage came apart on the inside of the door. Remove the inner door panel & u will see the linkage probably disconnected. find out where its disconnected & reconnect it. there may be a clip which holds it together which u may find in the bottom of the door.
1helpful
Just replaced the wiper motor on Jetta and wipers still won't work
Have you replaced only the motor or including the gear box (where the input shaft to the linkages is located)?
97 Jetta. headlights and wipers don't work. Bought car used. Wires hanging down from column. How do I find the wiring or fuses for this problem I don't have manual. Single mom w/children HELP, plz!!!
you will need to remove the shroud around the steering column and look to see whats wrong ,it could just be the multiplug has fallen out but without a look i couldnt tell you offhand
97 jetta struts
To replace the struts, remove the strut/spring as an assembly from the car. You'll need a strut spring compressor to remove the spring. Take your time and compress the spring slowly and evenly. You'll be able to remove the strut after the spring is compressed far enough. Installation is reverse of removal.
2answers
97 vw jetta
pop off the distributer cap and dry it out well. Put it back on and it should work. This happened to my 97 jetta too...also if I go through large puddles at a quick speed this may happen too. There isn't good electrical contact with the moisture.
I need instructions on replacing struts and shocks on a 97 VW Jetta
The best thing to do is log on to Auto Zone and register, It's free and you should get the information your looking for. Keep me posted, be glad to help and if your having problems getting that information just let me know and i'll send if needed. Good luck and hope this helps. Oh and Auto zone also has loner tools for you to get the job done if you don't have a spring compressor for the struts.
2helpful
97 Jetta GLS - Horn honks when I turn the wheel to the left
sounds like there is something in the wrong place in the horn button. it makes contact when you turn left just as if you had pushed the horn button. i wonder does your airbag light ever come on, i mean not just in the startup sequence, that's normal. probably you need to take the horn button part of the steering wheel apart and get things back in the right place or maybe replace some parts, but because of the airbag being right there too it's not something i would recommend that you do yourself. accidentally setting off an airbag is not a good thing.
2helpful
97 jetta GT alarm won't let car start. how can i disable?
If you not good with a wrench don't try to remove it. I am not sure but you can try two different things one lock and unlock the driver side door about 3 time then put the key in the ignition and try to start it, someone else said to remove one of the battery cables wait about twenty min. or so and replace it and try. If you do have to have the guy fix make sure he takes it out and gives it to you.
98 GOLF GL 2ND AND 4TH SHIFTING PROBLEMS I READ ONE BLOG QUESTION FROM 97 GOLF OWNER WITH SAME PROBLEM AND SOLLUTIONS WERE SYNCHRO CONE AND SHIFT LINKAGE ROD END. CAN EITHER ONE OF THESE SOLUTIONS BE DONE...
look inside engine compartment, locate the transmission has metal linkage arms with plastic round end connection in to metal half ball mechanism , play with system, move it back and forward, side to side, they are behind transmission and left side of car standing on front, by playing You will notice free play in one, that's the bad one, look in to getting all new
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
