Question about Onkyo TX-SR501 Receiver
Stereo aux port
How do i connect aux to receiver? Specifically, an ipod/ipad without a dock. Can i use a mini jack to twin rca cable? Please do help.
2 Related Answers
Anonymous
  • 73 Answers
SOURCE: Ipod Dock connection
The Red, green, blue from this adaptor cable
http://store.apple.com/us/product/MB128LL/B?fnode=MTY1NDA0OQ&mco=MjE4ODM1NQ
go into any of the RGB inputs on the Onkyo
The R/W go into the corresponding inputs for audio, Red and White.
One thing to note,
IF you are running one source RGB like you want to do,
you may have to monitor output the video of the amp RGB to the TV, most of these amps do not like to mix HDMI with anything else.
So If you have one HDMI going out to the TV, this solution will not work. You should look at the manual for the Onkyo regarding what paths can pass at the same time. There is usually a small disclaimer in the HDMI section.
Hope that solves your question.
Posted on Jan 09, 2009
Chuck
  • 85 Answers
SOURCE: hooking Ipod to onkyo receiver
i pods use a different adapter for doing this. It plugs in the bottom using the big porton bottom and outputs the rca plugs this way. Ipods see too much resistance and protects the unit from burning out. check this out http://www.amazon.com/Logic3-iPod-RCA-Phono-Cable/dp/B00083D7WC
Posted on Feb 21, 2009
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
Oct 16, 2013 | Pioneer Audio Players & Recorders
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
Is there a way to hook up an ipod to this stereo so it will play the ipod music through the stereo? Can I purchase a docking station that will hook up to this stereo?
Just get an adapter for to connect from the Ipod headphone jack to a standard RCA cable pair. Jack into AUX or whatever available input you have.
Dec 05, 2009 | RCA RS2652 Shelf System
How do you hook up your ipod through the rca cable hookups in the back without the radio still playing?
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
Aug 14, 2009 | Pioneer DEH-2000 CD Changer
Need to connect my ipod to the receiver.
You can do this a couple of ways, depending on the model of iPod.
1. Almost every iPod has an 1/8" earphone jack. Almost every Receiver has RCA input jacks. At Radio Shack, or any store with an electronics section, ask them for an cable with the 1/8" earphone plug on one end and stereo RCA jacks on the other.
Plug the RCA jacks into the receiver, taking note of the name of the input (Aux, iPod, Tape, etc) and plug the other end into the iPod. Set your receiver for the input you're connected to and press Play on your iPod. Enjoy music.
2. From the Apple Store, or any iPod dealer, purchase an iPod Dock for your particular model. Ask the same friendly folks for an audio connection cable and do the same as above for the Receiver end. On the iPod end, just set the iPod into the dock and press Play.
Jul 26, 2009 | Audio Players & Recorders
Hooking up an external audio source (IPOD) to the Denon AVR 3803
Yes it is.  You will need to pick up a mini plug to stereo rca adapter.
Jan 07, 2009 | Denon AVR-3803 Receiver
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Onkyo TX-SR501 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
