Question about Radio Shack Wireless Weather Forecaster
The outside temperature keeps gonig blank - Radio Shack Wireless Weather Forecaster
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Auto trans keep gonig into manual mode
Bad electronics. Sensor, actuator solenoid, or TCM. None of it is an easy or cheap fix.
Aug 27, 2014 | 1995 Isuzu Rodeo
Fron Brakes keep gonig bad
Going bad ??? NOt sure what you mean by this, but I assume wearing quickly........i would suggest front caliper overhaul....repair/replace sticking slides as this can result in brakes dragging and have porr efficiency and excessive wear rate
Sep 22, 2010 | 2002 Pontiac Grand Am
Fuel injector fuse keeps blowing what is gonig on
check for a naked wire running metal aroun tuns and anywhere that there has been and kind of work done latley pls take time to rate this solution
Feb 17, 2009 | 1994 Chevrolet Caprice Classic
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
Oct 17, 2007 | TruTech T650-DR DVD Recorder
Radio Shack Wireless Weather Forecaster Logo
82 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
