Question about Nintendo DS Lite Console
Microphone not working
The microphone on my ds lite is not working......i have read somewhere you can change the mic volume level.......but cant seem to find a setting to do so?
the console hasnt been dropped or taken apart or anything like that , and i have checked the mic input for dirt etc and it is clear
Posted by speedyjay on
  • 11 more comments
  • Anonymous Dec 06, 2007
    my ds mic does not work. When i try to play mario party ds, the mic does not work, and i do not know what to do. help
  • carrievernon Dec 09, 2007
    ive just bought sims castaway and i need to blow into the mic to start the fire but the mic isnt workin, argh cant start the fire! any help guys?
  • Anonymous Dec 25, 2007
    yeh boy mine is the color recognition on brain age i've done all but swallow the console my ds lites mic is rite in the middle of the hinge and no matter were i hold i dont work'
    oldfart at
    http://www.sweetpeaspapap@comcast.net
  • helen811dogs Feb 15, 2008
    hi my daughters ds lite has never worked and im reading comments that u can try and change the volume selling on the menu.what menu ?where?please have you any idea if this problem is fixable
  • midge1 Feb 19, 2008
    got a game were you had to talk & the ds mic not picking my voice up & volume at it max
  • lufbnf Feb 22, 2008
    i ve just bought sims castaway and i need to blow into the mic to start
  • x_bex_x Aug 06, 2008
    i go on to mario party on ds and when i test the microphone on it nothing is detected on there my pink ds does but my sisters black ds and the other white ds doesn't detect anything doesn't any one know why this is????? thanks x
  • youngsales Sep 07, 2008
    I have a Nintendo ds lite and it's in pretty good condition i droped it and a chip of it fell of put just the out side chiped and the inside is still untouched.I have never taken it apart. I have cleaned it to see if there was dirt but nothing.I have used it before and it was working fine .I'f you have any way of helping me contact me at [email protected].
  • claire76 Sep 08, 2008
    mic on ds not working. how do you check volume on mic.
  • Anonymous Nov 08, 2008
    I dropped my DS and now for some reason it doesn't work on Mario Party DS!!!
  • Anonymous Dec 07, 2008
    my mic
  • Anonymous Dec 24, 2008
    Mic is not working
  • Anonymous Jan 01, 2009
    my ds mic. is not working and i can not find the volume changer for it because i think thats my problem
Anonymous
My DS's mic doesn't work either, i'm going to try a headset.
Posted on Feb 22, 2008
Anonymous
Adjust the proximity of microphone or call nintendo helpline 08706060247 which has a 24 month warranty
Posted on Oct 25, 2007
1 Related Answer
Anonymous
  • 17 Answers
SOURCE: microphone not working
The microphone level can only be adjusted in certain games. Have you tried using the mic in any other games? Most likely, the mic is simply defective; I have heard of more than one case of manufacturing defects with Nintendo DS microphones. How long have you had the system? If it is still under warranty, Nintendo should fix the system for free.
Posted on Jan 28, 2008
Tip
DS Lite microphone repair tips.
If your built in microphone on your DS lite is not working then there are
5 things I can suggest for you before you go ahead and buy a new one for replacement.
1) Make sure your volume is up, you may not be hearing it picking up (sounds obvious but worth a try).
2) Use a wooden coctail stick or similar and CAREFULLY remove any lint/fluff that may have collected in the mic slot (be careful not to dig too deep as this will damage the mic).
3) Use a hairdryer on a low setting to dry out any spittle that may have collected in the mic (please be careful not to let the ds get too hot as this will cause serious damage).
4) Test your external mic port by either connecting a mic if you have one and if not get a slither of metal (such as a sewing needle or small/precision flat-head screwdriver) and give it a wiggle in the mic port. (the mic port is the rectangled hole with two metal pins in it net to the 3.5mm headphone jack), if you get a reaction thats a good sign and shows that, if it comes down to it you can use an external mic until you get the problem sorted.
and finally...
5) I must stress that this last tip requires you to have a steady and gentle hand... plus a bit of congidence :).
Use a sewing needle or pin to gently pry the two metal pins in the mic jack upwards, the front of the pins are fixed but further back the pins float, you need to raise these enough to sever the connection these pins are making as when these pins are making a connection they over-ride the internal mic.
If all these five tips fail to work for you then your only option is to replace the microphone, it can easily be done with basic/moderate D.I.Y skills. A replacement DS lite microphone is readily avaliable and cheap on ebay. If you need help with a microphone replacement please feel free to contact me and I will do my best to help you out.
I hope this helps and would like to say I accept no responsability for any damage that may occur to your ds lite when following my tips.
Regards,
SOD69
on Feb 06, 2010 | Nintendo DS Lite Console
My nintendo ds lite microphone isn't working!
suspect the mic has gone faulty if it went all of a sudden.
Jul 04, 2009 | Nintendo DS Lite Console
What game are you playing? On some games if it has the option of using the microphone you may be able to adjust the settings in t he game but when the game is removed they go back to default. Other than that I haven't seen anything that really talks about a microphone level setting.
Mar 01, 2009 | Nintendo DS Lite Console
Microphone on ds
Hi - we had the same problem on ours - caused by overenthusiastic blowing (with spit!!!!) microphone shorts out. If shorted at mic it is easily fixable - do as we have done and buy a Game earpiece and mic combined for about a fiver. If it has shorted at motherboard, you need a new one.... sorry...
Feb 15, 2009 | Nintendo DS Lite Console
Yea where IN the DS Lite menu?
Sep 06, 2008 | Nintendo DS Lite Console
Jan 27, 2008 | Nintendo DS Console
Mic not working
Try to speak away from the device until it starts to work.
Jan 04, 2008 | Nintendo DS Lite Console
Nintendo ds lite microphone doesnt work
I fixed the MIC on my DS LITE very easily, after first replacing the MIC with a new one and finding that it still did not work (not an easy thing to replace either)! The internal MIC signal is routed to a contact at the front edge of the DS, which allows the internal MIC to be disconnected when an external MIC is connected. If this contact (which is normally held closed by the springy nature of the contact) gets dirty, then it effectively goes open circuit, disconnecting the internal MIC signal. You can use a cotton bud and a little WD-40 (contact cleaner) to clean the contact (clean the two pins next to the 3.5mm jack connector) to restore the electrical contact. Takes 5 minutes and is a LOT easier and cheaper than replacing the MIC or paying someone to repair it!
Oct 30, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
2,024 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
