Question about Nortel Norstar Meridian Phone System With Voicemail And 7 Phones M7310 M7324
Help with locating extensions
How do I find out what the extensions are on each phone?
Norm Pearl
  • 108 Answers
Press Feature * 0 (feature star zero) then each intercom or key. The display will show the number
Posted on May 01, 2017
Relocate Extension to New Handset Location
Walking extension
dial*727 extn number then the pin
Feb 10, 2014 | Panasonic KXDT343 Phone
Change a call forward phone number on extension, toshiba dkt3020sd
you have to obtain the voicemail users guide for administrators. This can be found at http://www.telecom.toshiba.com/ and if you have a problem a dealer may be located who can do this for you.
Feb 20, 2013 | Toshiba DKT3020SD Corded Phone
Two extension number not working
Hi, what causes extension number not working is because the IC that controls the number is damaged and it will need to be replaced.
The IC is a tiny chip located on the board of the phone. To be able to locate where the IC is inside the phone , You will need to unscrew the phone and Locate it.
But it's a little bit more tiny and technical than you expect. You might need to consult a skill personnel for assistance to help you locate the particular IC that is damaged and help you replaced.
Thanks for using fixya........
Jan 05, 2011 | Cell Phones
Need some help in configuring/personalizing Avaya 4610/4621 SW IP phones. I have read through all of the settings specified in 46xxsettings.txt file located at...
Sort of. You can set the .txtx file for the items that are currently in it. BUT, once the phone gets the file, all you need to do is put the extension number in, thne the personal info is grabbed from the callsrv IP, and the user information is automatically inserted,
Oct 07, 2010 | Avaya 4610
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Jan 20, 2009 | NorStar M7310 Corded Phone
D1232 Panasonic - Removing Long distance restriction
Changing the Class of Service COS of that extension to "1" will allow it to dial anything.
In a TD system, that is a 2-step process, because you have to find where the extenion jack is located in the system.
Go into programming and dial 003. If you press the SP PHONE button, it will step you through all the ports in the system and give you extension numbers. To start 01-1 will be 101 01-2 201 02-1 102 etc. Since you're in a motel, it should be renumbered to match the rooms and if you started with 100 or eliminated 113 your whole plan may be different.
Once you find the jack number for your station, press the HOLD button and dial 601 SP PHONE and the 2 digit jack number from above. You will be looking at your extension COS. Dial 1 STORE and it will turn off that extension's toll restrictions.
Please rate this solution and let me know if you had any problems following this instructions.
Carl
Dec 11, 2008 | Panasonic KX-T7453 Corded Phone
Change/reprogram extensions
The easiest way to do this is move the cross connect in the closet. Get the jack number from each location and swapped the cross connect(wire). You could change the extension number in MB4-10 but it depends on the type of system you have.
Nov 18, 2008 | NEC DTU 8-1 Corded Phone
Major problem.. please help
Look carefully at the jack the phone and all your other phones are plugged into. Water or corrosion on the data pair from any location make Panasonic systems go crazy.
Carl
Aug 18, 2008 | Panasonic KX-T7730 Corded Phone
Stratagy DK issues
The night key on the phone only changes the location the trunks or lines ring. The voicemail should be set up with 990 as an " Introduction ", Thank you for calling ABC Company and 991 is the " Instructions ", If you know your party's extension please enter it now. The mail boxes should match the extensions and ring the phone. you need to verify the extension field in each mailbox to make sure they match. Do you have access to the voicemail programming ?
May 22, 2008 | Toshiba DKT-2010 Corded Phone
Nortel Norstar Meridian Phone System With Voicemail And 7 Phones M7310 M7324 Logo
54 people viewed this question
Top Nortel Lands Phones Experts
Marvin
Marvin
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
