It sounds like your PTAC (packaged terminal air conditioner) unit is malfunctioning. When the thermostat is set to heating mode, the PTAC should be blowing warm air, not cold air. There are a few possible causes for this issue:
The PTAC may be low on refrigerant. If the unit is low on refrigerant, it may not be able to properly heat the air.
The PTAC's reversing valve may be stuck in the cooling position. The reversing valve is responsible for switching the flow of refrigerant between heating and cooling mode. If it is stuck in the cooling position, the PTAC will blow cold air even when the thermostat is set to heating mode.
The PTAC's heating element may be malfunctioning. If the heating element is not functioning properly, the PTAC will not be able to heat the air.
I recommend contacting a trained HVAC technician to diagnose and fix the issue with your PTAC. They will be able to determine the cause of the problem and repair it properly.
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
