Question about D-Link AirPlus DI-524 Wireless Router
I forget pre shared key how can i connect net om my phone
2 Related Answers
Anonymous
  • 104 Answers
SOURCE: connect dlink to n95
Hello...the pre-shared key is also known as the network key, and you can find it within your router settings.
Open a web browser, and login to your router by typing http://192.168.0.1 into the address bar.
You are prompted for a username and password. Enter username: admin and leave the password blank, or enter your password if you have set one.
Go to Home >Wireless. You should see your pre-shared key, or network key there.
Hope this helps you, but please come back to Fixya if this does not work or you need further help.
Posted on Jan 17, 2009
Anonymous
SOURCE: want to know the pre shared key
From a computer connected to your router, in a browser window, type http://192.168.0.1 in the address bar. Type your user name and password - if you have - and voila, you've accessed your router configuration page.
Posted on Jun 28, 2010
Forgotten pre-shared key for D-Link Router
I thought there was a check box in this model that enabled you to see the password/key. If not then you may have to do a factory reset and set-up everything from scratch. Cannot remember if this model has a guest mode, but if the device you are connecting is not critical, TV, BlueRay, Roku etc, then enable the guest mode without a password to connect. These devices will NOT connect to other things on the network, but if they only need internet access it may be OK.
Dec 30, 2011 | D-Link DIR-615 Router
Im trying to use my mobile phone through wifi on my home broad band but says i need a pre shared key number how do i find that number
The pre-shared key is nothing but the password you use to connect to your home network. Just type in the password and connect
Jun 14, 2011 | NetGear WGR614 Wireless Router
Airtel binatone router & nokia 5800 wlan not connecting.demand pre shared key?
take the key off the bottom of your router and type it into the phone... its a security password
Dec 03, 2010 | Cell Phones
I have a intellinet model 503693 router. my i phone connects automaticly when i am near (20 meters outside) how do i get it to request a password? the neighbours are using my internet connection.
First let me give you steps how you can make your router secure from unauthorised access which your neighbours are doing
You need to login to the router setup page after connecting the router with pc via a cable
Connect to the Wireless G Broadband Router by entering http://192.168.1.254in the address field of your Web browser. Once you’ve logged in, the browser will display the administrator menu on the left-hand side of the screen, with the five configuration options — Wireless (Settings)
Encryption — Select "None," "WEP," "WPA," WPA2" or "WPA2 Mixed."
• WEP: Wired Equivalent Protocol.
• WPA: WI-FI Protected Access (WPA) is an intermediate solution for security issues. It uses Temporal Key Integrity Protocol (TKIP) to replace WEP.
WPA Authentication Mode — "Enterprise" uses an external authentication server (e.g., RADIUS) and EAP just as IEEE 802.1X does; "Personal" uses pre-shared keys without the need for additional servers. Both options will generate a master session key for the authenticator (AP) and supplicant (client station).
WPA Cipher Suite/WPA2 Cipher Suite — Choose either TKIP or AES.
Pre-Shared Key Format — Select passphrase or hex characters. Pre-Shared Key — Enter up to 128 characters.
Authentication RADIUS Server — Enter a port, IP address and password.
You can also read the manual of your router from the link i am providing
Let me know if this will help
Nov 27, 2009 | Intellinet Active Networking Intellinet...
My nokia n96 is asking me for wpa pre-shared key when i try to connect to the internet. where do i find it. thanks
A wpa pre-shared key is required when you try to connect to a secure wifi connection. You will need that key for using that connection. Otherwise just use another web profile from your service provider.
Your welcome!
Nov 02, 2009 | Nokia N96 Smartphone
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
Sep 02, 2009 | SonicWALL Pro 2040 Firewall
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect dlink to n95
Impossible N95 8GB wi-fi connection
try this blog. it might help you. i will keep looking
Jan 19, 2008 | Cell Phones
D-Link AirPlus DI-524 Wireless Router Logo
19 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
