Question about SanDisk 2GB microSD Memory Card
My sandisk ultra 16gb memory card showing 0 mb used and 0 mb free apace shown
Whenever i want to faotma the ard it shows unable to format
5 Related Answers
laikexpert
laikexpert
  • 281 Answers
SOURCE: I CANT FORMAT IT IM USING WINDOWS I HAVE AN 8 GB
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 08, 2010
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: my sandisk memory card is 2GB storage. I have
For formatting please follow the beolow procedure
1.Go to my computer and right click the driver which you want to format.
2.There wil an option called as 'Format'.
3.Click on it you it will open an Box,In that tick the quick format box and click on format button.
4.Your drive wil get formatted.
Thanx
Posted on Jul 21, 2010
Anonymous
  • 109 Answers
SOURCE: sandisk 2gb sd card unable
Hi
Please follow these steps to recover the data from your memory card.
1. Go to http://www.recovermemorycards.com/
2. Download the software from the website.
3. Install it on your computer and recover the data from memory card
Posted on Jul 31, 2010
Anonymous
SOURCE: my sandisk 1GB memory card
memory card not formatted my pc and not open
Posted on Mar 19, 2011
myk415
  • 36 Answers
SOURCE: My sandisk cruzer 4 GB
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Posted on Jul 04, 2011
Whenever formatting my USB Data Traveler (Kingston 2GB DT 172GB ) (CN 051008 5V), my window always show me " Windows was unable to complete the format. " and whenever i put it in my USB Port, it...
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive if you still want or need to format
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps"
Jul 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Respected Sir, I have Nokia N73 hackked Mobile whenever i install the softwares it was not installed showing the msg corrrupt file, unable to install pls sir is there any solution for this problem
this specific error occurs in the hacked mobile phones when the hack is not installed properly.
you have to format both the phone and memory card in order to install the applications.
to format phone dial *#7780# to format the memory card remove it from phone nad connect it directly to a pc and format it there.
after formatting, properly reinstall the hack.
hope it helps
Mar 11, 2011 | Nokia N73 Cellular Phone
My nokia 5800 shows unable to perform bluetooth operation whenever i switch on the bluetooth.
I have Nokia5800, which causes an problem regarding bluetooth.whenever i start bluetooth it show me an error message "unable to perform bluetooth operation"
Oct 25, 2010 | Nokia 5800 XpressMusic Smartphone
No multimedia c ard support
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 13, 2010 | Nokia 5200 Cellular Phone
Unable to perform bluetooth operation
the power on/off to
press and hold
After a few
will
Apr 12, 2010 | Nokia E61i Cellular Phone
I can not get a new memory card to format. When
That is a really old camera. Is it a new card? The camera may not support the size of the new card. Being released in 2002, I doubt it will handle 2GB cards.
Check and make sure the ard you are putting in does not have the write protect on.
Feb 28, 2010 | Nikon Coolpix 4300 Digital Camera
Unable to open my pendrive
Use fixya.com
I have posted free recovery software.
http://www.fixya.com/support/t3810754-find_any_files_sandisk_m2_1gb_when
The name is getdata back.
You can download card recovery also its free.
http://www.cardrecovery.com/download.asp
ok
Any other help.
You are most welcome.
Regards
Uttam
Feb 18, 2010 | Electronics - Others
How do i formate my psp memory stick
plug in ur PSP in the computer and then format it.
Aug 20, 2009 | Sony PlayStation Portable (PSP) Console
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SanDisk 2GB microSD Memory Card Logo
131 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
